b20vtec problems
Old Aug 6, 2006 | 08:09 PM
zhan28's Avatar
Default b20vtec problems
so with my b20vtec, when i went to the dyno, the car would engage vtec, but when that happens, the power drops. you can hear the vtec engaging, and it's loud as hell, but there's no power there. anyone have similar problems or might be able to help? i was told it might be the rocker arms, but if the rocker arms are shot, the motor shouldn't even engage in vtec correct? idk, i'm so confused. could it be the tuning? but even with a bad tune it should be completely losing power when vtec comes in?
Old Aug 6, 2006 | 11:51 PM
fmrprojects's Avatar
Default Re: b20vtec problems (zhan28)
what header/exhaust are you running. to much restriction maybe and not enough air flow for high end
Old Aug 7, 2006 | 07:08 AM
zhan28's Avatar
dc headers with old school trust exhaust. 2.5 piping
Old Aug 7, 2006 | 07:13 AM
Lucid_Dream's Avatar
this one has got me stumped also. never heard of that. good luck on getting it worked out.
Old Aug 7, 2006 | 08:32 AM
darklyte's Avatar
have you changed your fuel system(fuel pump-injectors,pressure regulator?if not , i think you should upgrade and get it tuned after that..
my friend had the same problem and it was solved by changing up his fuel system.. good luck....
Old Aug 7, 2006 | 09:03 AM
b16ek's Avatar
try replacing ur dizzy cap rotor plugs wires
Old Aug 7, 2006 | 12:51 PM
zhan28's Avatar
miner-dma i will try that, the motor has been sitting for a while
Old Aug 7, 2006 | 06:57 PM
b20powereDA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">what header/exhaust are you running. to much restriction maybe and not enough air flow for high end</TD></TR></TABLE>
people run stock i/h/e on b20 vtecs all the time. not the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miner-dma &raquo;</TD></TR><TR><TD CLASS="quote">have you changed your fuel system(fuel pump-injectors,pressure regulator?if not , i think you should upgrade and get it tuned after that..
my friend had the same problem and it was solved by changing up his fuel system.. good luck....</TD></TR></TABLE>
people run stock fuel system all the time, including me. not the problem. so jus eliminate these 2.
Old Aug 7, 2006 | 07:06 PM
loudassVTEC's Avatar
Default Re: b20vtec problems (b20powereDA)
Sounds like cam timing. Had the same problem. Vtec engaged so loudly, it scared people driving next to me...but all it did was make noise, it didn't go anywhere. I just about lost to a stock CRX Si. I replaced the head gasket, and I found the cam timing was off a tooth. Fixed that problem, and the car pulls like it should now. Especially with a tune!
Good luck
Old Aug 7, 2006 | 07:53 PM
zhan28's Avatar
b20powerda: so what would you suggest...?
loudassvtec: i'm pretty sure the cam gear timing is right, because i just had my timing belt replaced, also hybrid motor timing is always a bit off, but i'll def check it again.
thanks for the suggestions guys, keep it coming! honda-tech is the best!
Old Aug 7, 2006 | 08:15 PM
Default Re: (zhan28)
when u went to the dynbo were u going to get it tuned? did u put it on a wideband? whats ur a/f ratio?
Old Aug 7, 2006 | 09:20 PM
zhan28's Avatar
it was a while ago, i think it was 12 to 1 before vtec, then 10 to 1 during vtec, i know that's really rich, but should it still have absolutely no power at all tho?
Old Aug 8, 2006 | 07:50 AM
whats the build and what kind of #'s were they?
Old Aug 8, 2006 | 09:39 AM
darklyte's Avatar
yea try it .i would try a walbro fuel pump..
i drove my friends b20 vtec and vtec is still working very good...
good luck man...
Old Aug 8, 2006 | 03:10 PM
zhan28's Avatar
like i said, stock bottom end, skunk2 stg 1 cams, everything else stock. it made 112 whp before vtec, then died...:-(
Old Aug 8, 2006 | 03:18 PM
zhan28's Avatar
by died i mean no more power
Old Aug 8, 2006 | 03:53 PM
XLR8 GS-R's Avatar
Are there any check engine lights? Fuel pump would not be the problem either...
Old Aug 8, 2006 | 07:36 PM
zhan28's Avatar
there was a o2 sensor cel i think, but i'm pretty sure the tuner fixed it
Old Aug 13, 2006 | 06:28 PM
XLR8 GS-R's Avatar
If u havent fixed the prob yet- my guess would be lack of oil pressure. Thats all i can think of as of now. A bad vtec solenoid would not let the motor engage in vtec but if its engaging fine but with no power i say there is low oil pressure.
Old Aug 13, 2006 | 06:29 PM
XLR8 GS-R's Avatar
Default Re: (XLR8 GS-R)
A bad tune would also do it- run stock ecu
are there any odd noises?
dustin jones
Engine Management and Tuning
Aug 19, 2017 09:05 AM
Reireii
13
Jun 26, 2017 08:54 AM
turboteg90
12
Nov 3, 2009 10:03 PM
tales sol
Apr 15, 2009 03:56 PM
g2tegsown
Jun 3, 2007 05:29 PM
