Kenwood Amp problem(s)
Old Aug 6, 2006 | 05:29 PM
del sol1658's Avatar
Default Kenwood Amp problem(s)
First off, SCREW KENWOOD
I posted on here yesterday on how my new 10in sub wouldnt play, just cut out every sec and amp would go into protective mode.
Well I fixed it by opening the box and switched the + and - wires going into the sub.
The sub sounded great, drove around all last night and today with it on.
Today I was heading home from work and out of nowhere, my sub cut out. Came home and poped the trunk and there it was, protecive mode....Ive re-arranged everywire, checked my grounds, check all fuses, It just wont play. It makes a weird clicking noise and the protecive mode comes on and all my lights dim and even my motor hesitates for one second.
I got fed up with it tonight and unpluged the wires that were connected to the amp going to the box and as soon as i did that it came out protective mode and seemed fine
Any ideas?
Sorry for the typo's and grammer errors, floridas heat sucks
Old Aug 7, 2006 | 11:30 AM
8520's Avatar
Default Re: Kenwood Amp problem(s) (del sol1658)
What model numbers? Used or new?
Old Aug 7, 2006 | 12:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: Kenwood Amp problem(s) (a_s_ol_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">What model numbers? Used or new?</TD></TR></TABLE> Ditto.... but what I want to know is how many subs and the make and model of it/them.
If the amp goes out of protection mode when sub(s) is/are disconnected, I would start looking for a problem with the sub(s) or it's/their wiring, although problem may still be with the amp.
Also where and how is the amp grounded, and what kind of fuse is being used on the amps power wire, [by the batt]? 94
Old Aug 8, 2006 | 05:04 PM
KWK-DB8's Avatar
i know whats wrong youre amp says kenwood on it
miss.Soshinoya
Audio / Security / Video
Jul 29, 2010 03:58 PM
DeliveryM2n
Nov 30, 2009 05:53 AM
deerman2701
Oct 9, 2008 07:48 PM
jxj220z28
May 26, 2005 05:12 AM
shamoo
Oct 18, 2002 05:38 PM
