what is the timing setting for stock ITR...and..how do you check it
Hi again dudes..
what is the stock timing for a 98 ITR? if i want to check the setting, can i do this myself, or do i need to go to the garage?
thanks for any info
thanks for any info
The stock ignition timing is between 14 to 16 degrees BTDC. The best timing is at 18 degrees BTDC (depending on your set-up of course). To check it yourseft you would need a timing light. I know there is a website explaining how to do it but can't get my finger on it.
[Modified by JPP, 1:09 PM 4/24/2002]
well... for a stock 55hp shot zex kit, stock setting should be ok. I have to check my plugs for black specs or signs of detonation, i just want to double check before i blow anything
SOHC_MShue
Nov 30, 2003 07:54 PM
BoostedGSRBubble
Nov 18, 2001 09:25 AM
