Losing Oil Pressure and Oil
Old Apr 24, 2002 | 08:47 AM
jimburroughs's Avatar
Default Losing Oil Pressure and Oil
I just changed my timing belts, 91 Accord, after 220K. Noticed pressure light would flash after 20 minutes of driving. Removed sending switch to check pressure- After 5 minutes of reving at 3krpm pressure would drop from 75psi to under 10psi @ (3krpm). Oil would then begin to leak at bottom of timing cover, just below crank shaft. Oil was not hot, but cold, as if it never reached the internal parts. Changed oil and filter, but still same results. Can any one diagnose this problem. I will hate to buy a new motor.
Old Apr 24, 2002 | 10:59 AM
Crazydave's Avatar
Default Re: Losing Oil Pressure and Oil (jimburroughs)
sound like an oil seal on the oil pump
Old Apr 24, 2002 | 11:27 AM
b19coupe's Avatar
Default Re: Losing Oil Pressure and Oil (Crazydave)
You need to pull the timing cover. Possible source of leak(s) cam seal, balancer shaft seal,crank seal, oil pump seal. If your oil pressure is low, you risk major damage to the engine. Fix it now, I would not recommend driving it until the problem is resolved.
ndex
Jan 28, 2013 06:31 AM
hatchedeg
12
Feb 2, 2008 10:55 AM
aznd87
Nov 6, 2006 01:32 PM
toooslow
Oct 19, 2003 04:05 PM
jimburroughs
May 14, 2002 10:14 AM
