Need Some Electrical help!! Drag car wiring harness
Old Aug 6, 2006 | 11:22 AM
JDMlyfestyle's Avatar
Default Need Some Electrical help!! Drag car wiring harness
I was wondering if anyone has a Wiring Diagram laid out for a Drag car.
Just Curious if you are still using the stock Engine Harness or if you are wiring everything straight to the ECU.
Thanks,
Old Aug 6, 2006 | 12:53 PM
speedworks's Avatar
Default Re: Need Some Electrical help!! Drag car wiring harness (JDMlyfestyle)
i am going to use the engine harness from a 96-2000 civic and just pick out what i dont need.
Old Aug 6, 2006 | 01:04 PM
Default Re: Need Some Electrical help!! Drag car wiring harness (speedworks)
but what wires are you using to hook up the rest of the car.. are you using the main relay? Underhood Fuse box? Dash Fuse box?
Old Aug 6, 2006 | 01:09 PM
MrParks's Avatar
make your own wiring harness isnt that difficult just time consuming.... mine took about 80 hours but it shouldnt take any longer than 30
Old Aug 6, 2006 | 01:13 PM
Default Re: Need Some Electrical help!! Drag car wiring harness (GHOSTWORKS)
im very good with wiring so im fairly confident on doing it. i just need a basic wiring diagram to do it.
Im going to bypass the main relay and all that so ill just feed Ignition 12v for the injectors.
Here is a pic of the Relay board that im most likely going to use
Old Aug 6, 2006 | 01:18 PM
MrParks's Avatar
sorry about that i didnt read your thread all the way through, if your gonna keep your chassis harness why just do the engine arness its not going to save you anything but it will give you a headache just stick with the stock harness and go race.
Old Aug 6, 2006 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GHOSTWORKS &raquo;</TD></TR><TR><TD CLASS="quote">sorry about that i didnt read your thread all the way through, if your gonna keep your chassis harness why just do the engine arness its not going to save you anything but it will give you a headache just stick with the stock harness and go race. </TD></TR></TABLE>
what i really want to do is wire all the sensors from the engine straight to the ECU. ( Running S300 BTW)
THere is no heat no AC or anything like that.. i was just gonna tap off the ECU and run it to my ITR cluster.
only thing in the interior that is going to be kept is the ITR gauge cluster.
Old Aug 6, 2006 | 01:40 PM
Project-D's Avatar
I've built two before and have them running on 2 Drag Cars. We are going to be doing all the testing this summer, and I plan on having them mass produced over the winter.
Old Aug 6, 2006 | 01:44 PM
Default Re: (Project-D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project-D &raquo;</TD></TR><TR><TD CLASS="quote">I've built two before and have them running on 2 Drag Cars. We are going to be doing all the testing this summer, and I plan on having them mass produced over the winter.</TD></TR></TABLE>
thanks but i need mine in like 2 weeks and i prefer to do it my self that way i know whats going on with everything and if something messes up i can only blame my self. not knocking you at all by means. my friends have had some wiring done by companies and they had nothing but problems with the wiring so i prefer to do it my self.
Old Aug 6, 2006 | 04:56 PM
Kataku2K3's Avatar
Default Re: (JDMlyfestyle)
I'm sure I won't be much help here, but this is what my custom full race OE style (motors driven by factory ECUs) look like. As you can see they're basically a fully reworked OEM harness (I generally just start with OBDI Civic/Teg harnesses). Then all that's required is a 12V+ power, ground, and starter signal.
Old Aug 6, 2006 | 05:45 PM
Default Re: (Kataku2K3)
Dayum that looks pretty sweet. what do you charge for a harness like that?
Old Aug 6, 2006 | 07:02 PM
matt k's Avatar
same way i do mine
Old Aug 6, 2006 | 07:18 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure I won't be much help here, but this is what my custom full race OE style (motors driven by factory ECUs) look like. As you can see they're basically a fully reworked OEM harness (I generally just start with OBDI Civic/Teg harnesses). Then all that's required is a 12V+ power, ground, and starter signal.
Old Aug 6, 2006 | 08:00 PM
shant's Avatar
Default Re: (JSpin)
anything for k series in eg with kpro?
Old Aug 6, 2006 | 08:04 PM
1 2 NV's Avatar
Default Re: (JSpin)
just unpin the wires going to your ECU that dont associate with your guage cluster. ill be honest with you though, its a pain in the *** and takes way too much time considering the amount of **** you actually get rid of. i was still using a stock GSR guage cluster and GSR dash in a 92 civic hatch at the time.
thats what i was running until this year. then i ditched my dash and used my factory engine harness.
i made my own harness to a switch panel. if you need it within 2 weeks good luck. its very time consuming and using that relay board just seems like it could get a little complicated.
i have power coming in feeding a terminal strip then going to a main switch which then goes to a fused distribution block, then back to the associated switch for what its running then out to the piece of equipment. sounds complicated but its really easy. the hardest part was making sure everything had power.
i spent 30 hrs in one weekend trouble shooting my harness cause i wasnt getting power to the ignitor or injectors. then i found out my regulator didnt have power either so my alternator wasnt charging. once that was figured out i havent had any problems since. ive been very happy with the results.
Old Aug 6, 2006 | 08:35 PM
lol so does someone have a basic schematic to follow. i want it down and out so i know if something ever goes wrong then i will know exactly where to look
Old Aug 7, 2006 | 08:42 AM
.nate's Avatar
What's wrong with using the OEM schematic and cutting out the crap you don't need?
Old Aug 7, 2006 | 09:02 AM
boosted94cx's Avatar
* B A N N E D *
whats the point in doing it anyways...not liek it'll give you much of a weight reduction, and it'd be easier with all the wires there than half missing and routed a different way.
Old Aug 7, 2006 | 11:18 AM
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">What's wrong with using the OEM schematic and cutting out the crap you don't need?</TD></TR></TABLE>
lol take apart an interior harness and find out. its a pain in the ******* ***. i just want it all to be simple.
Push start Ignition, Fuel Pump ECU Power. and lights and that is it.
Old Aug 7, 2006 | 02:32 PM
Kataku2K3's Avatar
Default Re: (shant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shant &raquo;</TD></TR><TR><TD CLASS="quote">anything for k series in eg with kpro?</TD></TR></TABLE>
Off topic once again, but here's my K20/EJ plug-n-play harness. Still have yet to do a full race, or OBDI EH/DC version, but I'll probably start one soon just for the hell of it.
Old Aug 8, 2006 | 06:24 AM
Chris22215's Avatar
Old Aug 8, 2006 | 12:39 PM
redboost10's Avatar
Default Re: (Chris22215)
damn adam, has scott mentioned doing the tec3r harness to you?
Old Aug 9, 2006 | 06:40 AM
Kataku2K3's Avatar
Default Re: (tgh99si)
What's up Travis! Yea, talked to Scott about it a little, a while back... Is that what EMS you're going to be running for sure now?
Old Aug 9, 2006 | 06:50 AM
redboost10's Avatar
yeah, just gotta add the cage onto the roll bar, and do the tube work, then get some measurements for the harness
Old Aug 17, 2006 | 09:14 AM
Bump for more info.
