crankshaft pulley
Old Aug 6, 2006 | 11:13 AM
airsoft's Avatar
Default crankshaft pulley
is the crank shaft pulley for the h23 and h22 the same? thanks
Old Aug 6, 2006 | 12:52 PM
airsoft's Avatar
Default Re: crankshaft pulley (airsoft)
anyone?
Old Aug 6, 2006 | 01:29 PM
.BigSexy's Avatar
most hood white kid
yes I believe so. The f series however, 1 less rib in the pulley
Old Aug 6, 2006 | 01:42 PM
InvaderTrax's Avatar
Default Re: crankshaft pulley (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">yes I believe so. The f series however, 1 less rib in the pulley</TD></TR></TABLE>
You got that backwards. The H22 has one more rib then the H23/F22
Old Aug 6, 2006 | 01:49 PM
.BigSexy's Avatar
most hood white kid
Default Re: crankshaft pulley (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">
You got that backwards. The H22 has one more rib then the H23/F22</TD></TR></TABLE>
ok, sorry...I thought all H-seires have a 6 rib pulley whereas I know the f22 has a 5 rib pulley.
So its...
h22 = 6 rib pulley
h23/f22 = 5 rib pulley
correct?
Old Aug 6, 2006 | 10:37 PM
airsoft's Avatar
thanks, guess im a cheap megan one instead of more expensive oem one
Old Aug 6, 2006 | 10:50 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airsoft &raquo;</TD></TR><TR><TD CLASS="quote">thanks, guess im a cheap megan one instead of more expensive oem one</TD></TR></TABLE>
why do u need one? I have an h22 crank pulley for sale if you want.
Old Aug 6, 2006 | 10:52 PM
airsoft's Avatar
i just need one for an h23 a replacement one nuthing fancy
Old Aug 6, 2006 | 10:54 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airsoft &raquo;</TD></TR><TR><TD CLASS="quote">i just need one for an h23 a replacement one nuthing fancy</TD></TR></TABLE>
pm'd
Old Aug 6, 2006 | 11:23 PM
airsoft's Avatar
ok, so would a 6 ribbed pulley work if you were using a 5 ribed belt? i keep finding cheap oem h22 crankshaft pulleys but i want to make sure it'll work no problem for an h23.
Modified by airsoft at 1:00 AM 8/7/2006
Old Aug 7, 2006 | 07:02 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airsoft &raquo;</TD></TR><TR><TD CLASS="quote">ok, so would a 6 ribbed pulley work if you were using a 5 ribed belt? i keep finding cheap oem h22 crankshaft pulleys but i want to make sure it'll work no problem for an h23.
Modified by airsoft at 1:00 AM 8/7/2006</TD></TR></TABLE>
it will work, if you just need a temporary fix...but I would search for the pulley to fit your belt. Like i said, Im gonna see how many ribs are on my pulley when I go to my grandfathers house today, and see if it will work for you.
Old Aug 7, 2006 | 10:42 AM
v4lu3s's Avatar
RTFM
afaik the h22 also uses different belt lengths. least when i put the f22 pulley i had on hand onto my wifes lude i had issues with belt sizing.
snowblind7x
May 13, 2007 11:51 PM
user 720822-1
Apr 20, 2007 06:11 AM
Vilmar
Nov 26, 2006 04:11 AM
dreams190
May 17, 2006 02:49 PM
4bidden
Apr 26, 2002 06:19 AM
