whats causing this damn oil leak
did you make sure when you took off your old filter that the seal didn't stay partly attached to the block? has it only been doing it since your last oil change or what?
ok either the seal has a leak in it (previously stated) OR look above the filter where the oil pressure sending unit it and it may be leaking from there, OR check the back side of the valve cover gasket. All of these are candidates.
