help.. vtec wont kick in
Old Aug 6, 2006 | 08:04 AM
epak's Avatar
Default help.. vtec wont kick in
i just swapped a gsr motor into my civic lx... and for some reason the vtec wont kick in and it redlines at 7 and not at 8... what could be wrong??
Old Aug 6, 2006 | 08:40 AM
keemosaki's Avatar
Default Re: help.. vtec wont kick in (epak)
Did you use the GSR ECU?
Did you check oil level?
Do you have oil pressure?
Is your car warmed up?
Everything above has to be right or else it wont work.
Old Aug 6, 2006 | 08:45 AM
epak's Avatar
Default Re: help.. vtec wont kick in (keemosaki)
well i got the motor and the ecu from some dude.. i no the motor is legit but im very sceptical about the ecu he gave me... so that could be a reason why vtec wont kick in and i cant redline to 8...
thanks
Old Aug 6, 2006 | 08:47 AM
epak's Avatar
could that be the only reason why the vtec not kicking in and not redlining at 8.. or is there a possibility the motor is fucked up
Old Aug 6, 2006 | 09:11 AM
HondaHead211's Avatar
most likely its the ecu
Old Aug 6, 2006 | 09:13 AM
-JSpecEk*9-'s Avatar
Default Re: (HondaHead211)
wha code is on the ecu?
Old Aug 6, 2006 | 09:36 AM
epak's Avatar
Default Re: (JDMEK-9)
where do i get the code??? . . will i be able to tell if its a gsr ecu or not from that??
Old Aug 6, 2006 | 11:08 AM
ci_v_ic's Avatar
Default Re: (epak)
is the motor and ecu obd-0, obd-1 or obd-2??
Old Aug 6, 2006 | 11:21 AM
Jason-'s Avatar
Default Re: (epak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epak &raquo;</TD></TR><TR><TD CLASS="quote">where do i get the code??? . . will i be able to tell if its a gsr ecu or not from that??</TD></TR></TABLE>
Theres a small little hanging plug next to the ecu... plug a little metal clip into it and run the car to ignition. Count the blinks. Long blink is 10. Short, quick blink is 1.
And the most common obd-1 gsr ecu is a p72, I believe. Look on the side of it and read the middle numbers/letters.
I hope I helped and am correct.
-Jason
Old Aug 6, 2006 | 11:55 AM
epak's Avatar
Default Re: (Jason-)
mine is a obd2 i think... its a 97 gsr motor
Old Aug 6, 2006 | 12:31 PM
epak's Avatar
okay i just looked at it and its a p72 ecu... will it work for a obd2 gsr motor???
Old Aug 6, 2006 | 01:41 PM
btleier's Avatar
well that should be the right ecu then.... did you run the appropriate wiring for the vtec.
Old Aug 6, 2006 | 03:05 PM
epak's Avatar
Default Re: (btleier)
well i took it to a shop and they did everything..
well okay the ecu is okay... they might of done the vtec wiring wront.. but why does the engine cut off at 7.5 when my redline is suppose to be at 8
Old Aug 6, 2006 | 06:37 PM
axtran's Avatar
your redline is actually 8200. VTEC you won't feel in a GSR anyway. it's at 4500. try this - drive in 3rd up to like 60mph, then hang around 4500 rpm, go past it a little and you'll feel it pull harder. that's as far as VTEC hits in a GSR. the B16 is dramatic, the B18C is meh. Your engine cutting off at 7500 rpm is usually the sign of a bad timing belt, or dying ECU.
Old Aug 6, 2006 | 06:51 PM
Rock Meathammer's Avatar
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">your redline is actually 8200. VTEC you won't feel in a GSR anyway. it's at 4500. try this - drive in 3rd up to like 60mph, then hang around 4500 rpm, go past it a little and you'll feel it pull harder. that's as far as VTEC hits in a GSR. the B16 is dramatic, the B18C is meh. Your engine cutting off at 7500 rpm is usually the sign of a bad timing belt, or dying ECU.</TD></TR></TABLE>
You're *** backwards on the b16 and the gsr. You can feel/hear a difference in both when VTEC engages. The GSR is more dramatic. If you don't believe me, look at the cam profiles of both engines. The GSR has a higher lift than the b16.
To the OP, If the car is obd2 as well, hook it up to any code reader and try to see whats going on. If you are unable to do this, take it back to the shop that did the install and have them look into it.
Old Aug 6, 2006 | 07:01 PM
Tuesdaynightfever's Avatar
Default Re: (B20 EJ6)
You won't feel vtec in a gsr? Are you serious?!?
To the OP: I'm going to go with the comment above...if a shop did the swap they should have no problem fixing any problem they might have made...
Old Aug 6, 2006 | 07:03 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
that may be true but the scondary butterflies arent actvated yet, not till 6k so vtec doesnt make THAT much more diffrence, untill the butterflies open
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
CarverGSR
Apr 26, 2008 12:16 PM
sony224422
Mar 1, 2007 02:16 PM
gots_a_sol
Aug 4, 2004 05:32 PM
ricekiller1
12
Feb 28, 2004 09:34 PM
