Internal / External wastegate Apexi turbo
Old Apr 24, 2002 | 07:32 AM
OPTIMUS's Avatar
New User
Default Internal / External wastegate Apexi turbo
Does the Apexi turbo for the Civics come with an internal or external wastegate?
Also if you have an interal wastegate, but you have a boost controller can you run a greater amount of boost, higher than the stock boost of say... 7psi.
If so, what do you think max boost will be?
AX53860 TURBO UPGRAGDE 1992-95 Honda Civic EX or Si (D16Z6)
[Modified by OPTIMUS, 6:00 PM 4/24/2002]
Old Apr 24, 2002 | 10:30 AM
SpeedRacerEX-R's Avatar
Default Re: Internal / External wastegate Apexi turbo (OPTIMUS)
It has internal wastegate. You can still control boost. You're just controlling how long the wastegate stays closed which is vacuum controlled. If you want to be a cheap ***, you can throw a t valve in there which creates a leak. The t valve is $2 just WATCH the boost gauge while you're experimenting with orifice sizes. Or go EBC and have that preset boost in each gear
Old Apr 24, 2002 | 10:36 AM
JaeOne3345's Avatar
Default Re: Internal / External wastegate Apexi turbo (SpeedRacerEX-R)
see that gold can? thats an internal wastegate. as far as boost goes..with a manual or electronic boost controller..u can keep it at 7psi and increase up to however efficietn the turbo is. some of the smaller turbos just cant push anymore awhile. plus..dont worry so much about how much the turbo can flow..u should be worried how much boost ur motor can handle safely and reliably.
Old Apr 24, 2002 | 11:05 AM
OPTIMUS's Avatar
New User
Default Re: Internal / External wastegate Apexi turbo (JaeOne3345)
Thanks fellas.
This is a new motor rebuild. The motor is built strong. Should be able to take 250hp to the wheels safely.
Do you think that the Apexi kit will be able to deliver 250horses?
What do you think that the MAX boost will be on the APEXi kit?
Old Apr 24, 2002 | 11:11 AM
What cr are your pistons? I'm going to say max boost will be between 12-14 psi. And I'd say with a bigger turbo, 250 whp is easily achievable. But with the apexi kit, it might be possible.
turbo_d
Jun 5, 2022 06:46 PM
Broken Gearbox
Jun 8, 2003 02:12 PM
Etylorcen
Jun 4, 2002 11:50 AM
OPTIMUS
Apr 26, 2002 01:09 PM
