1995 Honda Accord Windows
Old Aug 5, 2006 | 05:45 PM
bjrta's Avatar
Default 1995 Honda Accord Windows
Both front electric windows are hard to roll up. I have to grab the window to help it roll up. Going down no problem. Is it worn window guides, the motor is working. Thanks
Old Aug 5, 2006 | 06:47 PM
hondadude's Avatar
Default Re: 1995 Honda Accord Windows (bjrta)
Try spraying silicone in the run channels
Old Aug 6, 2006 | 12:39 PM
510cd5's Avatar
white lithium grease spray
Old Aug 6, 2006 | 02:49 PM
Honda-Master's Avatar
do not use silicone it dries out too fast,, use wd-40 if you have to.....
best way is to clean the run channel properly than lube it,,
Old Aug 6, 2006 | 05:23 PM
Accorn's Avatar
My passenger window did the same thing. Just changed the window seal today. Works perfect now.
Old Aug 6, 2006 | 05:47 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (Accorn)
My 95 accord windows roll up very very slowly, what should I do? Replace covers or lube or what? Where is the motor? Do I have to take the door apart.
Old Aug 7, 2006 | 07:20 AM
Duane_in_Japan's Avatar
Default Re: (m1ndless)
WD40 IS A WATER DISPLACEMENT, NOT A LUBE, hence the name, it evaperates too so it is no longer in my toolbox, you do not have to disassemble the door until you have to replace the window regulator, lube the rubber tracks for now.
flam2828
Jul 2, 2019 03:34 AM
Dev1996
Oct 20, 2015 06:28 AM
dvp95
May 17, 2007 07:34 AM
windcalmer
Aug 7, 2004 03:22 PM
