Wrong Pilot bearing ???
Old Aug 5, 2006 | 05:15 PM
Whorehey Nighten's Avatar
Default Wrong Pilot bearing ???
I have a fidanza flywheel ;and an act clutch kit; I went to put the pilot bearing in and it doesn't fit (way too big) I was assumoing I could use the act pilot bearing with the fidanza flywheel was I incorrect in thinking so.......
Old Aug 5, 2006 | 05:45 PM
Default Re: Wrong Pilot bearing ??? (9WON4)
up
Old Aug 5, 2006 | 10:09 PM
SuzukaBlueAP2's Avatar
So what do you want from us here?
If the pilot bearing doesn't fit, then you can't use it. Either use the one that is already in there (assuming there is one in the Findanza) or go buy one.
Old Aug 6, 2006 | 01:06 PM
Default Re: Wrong Pilot bearing ??? (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">So what do you want from us here?
If the pilot bearing doesn't fit, then you can't use it. Either use the one that is already in there (assuming there is one in the Findanza) or go buy one.</TD></TR></TABLE>
thanx hope it was worth your time 2 respond
Old Sep 4, 2006 | 05:41 PM
CHEFH22HATCH's Avatar
helpful response........... when u ripping up in that thing??????????????
mike93eh2
Mar 12, 2007 05:56 PM
crxpwr1
11
Oct 2, 2006 03:45 AM
95whitegizzer
Jun 10, 2004 05:58 AM
InfamousGSR
Apr 1, 2004 06:35 PM
1fastVX
Aug 22, 2002 05:43 PM
