HELP!! Clicking sound on my main relay
Old Aug 5, 2006 | 04:34 PM
acerz007's Avatar
Default HELP!! Clicking sound on my main relay
Background: 92 civic h/b w/ 1995 gsr motor-Turbo
Ok here's the problem. My engine surges quite violently when i'm moving and will eventually sputter and die. There are times when it will backfire loudly as well. The surging was never really an issue until now.
Things that I did before this happened:
- re-installed my turbo gauge (cobalt series) to feed off a constant power. However, during this process, the gauge shorted and i heard an audible *click* when it happened. I assumed it was just the gauge that fried
- The same night, we tried to re-chip my ECU for launch control and shift light. After we installed the freshly burnt chip (uberdata v1.66) the car would not start properly at all. We eventually found out that the chipping was faulty so we re-started a whole new basemap and it worked, though this is where the violent surges really start.
Things I did to try to fix the problem:
- Took out my newly installed gauges including all the wiring - Did not work
- Changed my distributor w/ a used one - Did not work
- Checked all my fuses - all intact
- re-burned the chip again - Did not work
- Scoped the engine - everything is functional
- Cleaned the IACV - Did not work
- Changed the plug wires to MSD - Did not work
- Changed the main relay w/ a used one - Did not work
- Checked the previous relay for damage or disconnection - None
Things that I think could be wrong:
- Something is grounded underneath my dash
- the ECU itself is shorted (but wouldn't this throw a code?)
- Fill in the blanks
Things that I've noticed:
- My RH turn blinker sometimes flash really fast (as if it's burnt a bulb) but both bulbs are intact
- Problem is worse when the weather is warm/hot and almost non-existent during early morning or night time driving.
Please help. This problem makes it difficult and dangerous to drive and also lowered down my mileage from 500km to 300km
Old Aug 6, 2006 | 12:54 PM
acerz007's Avatar
Default Re: HELP!! Clicking sound on my main relay (acerz007)
Can any help please? I know I sound desperate, that's because I am.
Old Aug 6, 2006 | 02:54 PM
civicstar's Avatar
usaully when the main relay clicks, it has to do with shorts or grounds. usually around the wiring harness. i had a problem with my main relay clicking and not starting because the ground to the harness near the thermostat housing was loose. tightend it up and it started fine. and it didnt even throw a code.
Old Aug 6, 2006 | 02:58 PM
josh green's Avatar
Check the ground on your thermostat. This happened to my car as well as a friends of mines.
Old Aug 6, 2006 | 03:00 PM
acerz007's Avatar
Default Re: HELP!! Clicking sound on my main relay (civicstar)
What i'm confused about is why would it act more severely on warm/hot weather as opposed to cold weather? Usually if it's a short or grounded wire, would it be a constant problem whether it be cold or hot?
Old Aug 6, 2006 | 03:01 PM
acerz007's Avatar
Default Re: (josh green)
What would I be looking for? burnt wire? loose/bad connection?
Old Aug 6, 2006 | 04:27 PM
civicstar's Avatar
Default Re: (acerz007)
for that ground on the thermostat, usually a loose or bad connection
Old Aug 7, 2006 | 05:53 PM
josh green's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acerz007 &raquo;</TD></TR><TR><TD CLASS="quote">What i'm confused about is why would it act more severely on warm/hot weather as opposed to cold weather? Usually if it's a short or grounded wire, would it be a constant problem whether it be cold or hot?</TD></TR></TABLE>
no it could do it just out of no where. like my friends.
Old Aug 7, 2006 | 07:19 PM
acerz007's Avatar
Thanks for the replies ... gonna take a look on Tuesday and see if it's any of those. Again thanks for the hand :D
Old Aug 8, 2006 | 08:50 AM
hondatek614's Avatar
this is just a thought....and because you switched out the relay I think it is safe to say it is not that part specifically. but who here is familiar with the infamous main relay problems in older civics and crx's? hot weather/cabin temperature causes the soldering to expand resulting in the main fuel relay not working. Like I said above, I'm assuming the relay isn't the prob, but it sounds like something of the same nature.
Old Aug 8, 2006 | 03:03 PM
acerz007's Avatar
I actually changed the relay before too for a brand new one. Apparently the new generation of main relays are better compared to the old one's. Maybe something along the line's of the relay itself could be the culprit. I just changed the ECU and chip and apparently the problem hasn't resurfaced, but the problem is it's cold and raining right now so I can't be 100% sure if it's really gone or not. Time will tell.
Built4Battle
Aug 10, 2010 05:01 PM
dmefb18
Sep 14, 2008 05:55 PM
muska411
Oct 30, 2003 07:06 AM
