how do i figure out whats wrong with my foglights?
Old Aug 5, 2006 | 03:07 PM
crdcz03's Avatar
Fortune Cookie Member
Default how do i figure out whats wrong with my foglights?
i rewired my foglights b/c i put an EL gauge cluster in with the correct dashboard wiring harness and the fogs worked just fine and then all the sudden i turned them on one day (i could have sworn they came on b/c i was facing a fence) and i drove through a puddle of water (not deep and i wasnt going fast... ive hit larger puddles going faster...) and by the time i got to the other end of the parking lot they were no longer working.
heres how my friend rewired it for me: i told him i wanted to use the stock fog switch so he figured out which two wires coming out of the switch were the power/ground and ran them to the relay. then he figured out which wires on the relay were the right ones and cut them off the relay and soldered them to the other two wires. we used an Prelude ETM and he did it all b/c he's much better with wiring than i am.
now, using the little wiring knowledge that i have, i took the bumper off and used a multimeter on the foglight harness and it shows power going to it. so then i opend the foglight and it shows power going to the bulb. so i figured it was the bulbs and bought new ones... it wasnt the bulbs
so does anyone know what else i can do to fix my fogs? JDM headlights dont exactly put out a great amount of light and the fogs REALLY help see things at night
Old Aug 5, 2006 | 03:22 PM
madcatz's Avatar
Craig H-3?
I had that problem with my USDM. It was a connector off of the extra wire. Double Check that. I thought it was the bulbs too, but lil did I know but the wire just jumped
Old Aug 5, 2006 | 03:28 PM
crdcz03's Avatar
H3C's
im getting power to the bulbs, but they dont light up
Old Aug 5, 2006 | 04:50 PM
madcatz's Avatar
ok so power from Fuse to bulbs. Power out of bulbs but no light?
Check across the bulb with power applied. I know it sounds stupid, but humor me please
Old Aug 5, 2006 | 06:05 PM
crdcz03's Avatar
Default Re: (madcatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">ok so power from Fuse to bulbs. Power out of bulbs but no light?
Check across the bulb with power applied. I know it sounds stupid, but humor me please</TD></TR></TABLE>
i put the positve multimeter on the back of the bulb and the neg on the ground spot inside the fog housing already...
Old Aug 5, 2006 | 07:39 PM
madcatz's Avatar
what voltage?
you get power to and through the bulbs. If the bulb doesnt light current is taking the path of least resistance.....meaning its shorted to ground....bypassing the filament. Thats all I can think of.
Old Aug 5, 2006 | 08:00 PM
crdcz03's Avatar
so how does it short to the ground?
and ill be damned if i have to take the bumper off again (its been off at least 10 times in the last 2 weeks)
Old Aug 5, 2006 | 08:12 PM
madcatz's Avatar
meh.....electricity is a stupid thing.....I deal with it every day....be happy to take only your front bumper off and you didnt have some of the engineers that designed my **** do the lude.
just to verify.....
battery to fuse: 12v
Fuse to Switch: 12v
Switch to Relay: 12v
Relay to Connection point between cabin and engine bay: 12v
Connection to Bulb: 12v
Bulb to Ground: 12v
Take off the bulb and measure resistance for me. Again for ***** and giggles Take a picture of what you are measuring too please
Old Aug 6, 2006 | 08:41 AM
crdcz03's Avatar
when will you be back? i may just wait that long
Old Aug 7, 2006 | 03:35 PM
madcatz's Avatar
OMG Craig I am in teh love with you.
your such a helpless dude.....
Yeah I can when I get back. I plan on making a trip down that way anyways....so I can always check it for you if you are as lazy as I think you are...110 days and counting till I am back stateside
Old Aug 7, 2006 | 09:00 PM
crdcz03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">OMG Craig I am in teh love with you.
Yeah I can when I get back. I plan on making a trip down that way anyways....so I can always check it for you if you are as lazy as I think you are...110 days and counting till I am back stateside</TD></TR></TABLE>
helpless when it comes to electricity anything else car related and im good to go
ill keep you updated on the situation... im going to try and have some other people look at it.
cisco1227
K Series
May 7, 2013 06:14 AM
plaidjppatches
Jan 13, 2011 12:29 PM
VI Boost
Dec 18, 2008 01:54 PM
EJ7CoUpE
Apr 8, 2008 09:40 AM
xerox445
Jan 27, 2004 12:15 PM
