IDLE PROBLEM
Old Aug 5, 2006 | 01:42 PM
lx130's Avatar
Default IDLE PROBLEM
so...my 90' CRX.. ZC SOHC
lateley ive been driving around in my car and whenever i idle in neutral at a stoplight or just go into neutral rpm drops and the car stalls...?!?!?!?!??!?!?!?!????? dont know why it does this!... help please
Old Aug 5, 2006 | 02:27 PM
SmogKing's Avatar
Default Re: IDLE PROBLEM (lx130)
How much rpm is it at idle? You can make the rpm higher by adjusting the srew at the throttle body. If no one has messed with it, there might be a plastic cap you have to dig into. It lays on top of the throttle body, Loosen that flat head screw then your intake will take in more air then your idle will be higher. Adjust to your setting however you like.
Old Aug 5, 2006 | 02:31 PM
charlee's Avatar
Default Re: IDLE PROBLEM (SmoGuy)
clean ur plenum. believe or not that helps a lot.
Old Aug 5, 2006 | 07:28 PM
lx130's Avatar
Default Re: IDLE PROBLEM (charlee)
whats plenum?
Old Aug 5, 2006 | 08:16 PM
charlee's Avatar
its the inside of ur intake manifiold. sorry for the misunderstanding
Cuda70
Jul 27, 2010 04:44 AM
philep_cb7_91
Feb 21, 2010 11:28 AM
TegraD
May 15, 2009 02:55 PM
vtec94civic
Aug 9, 2005 03:35 PM
Full Race A6
43
Aug 11, 2004 03:06 AM
