bosch unversial o2 sensor help??? wiring help ASAP
i just bought a bosch unerversal 02 sensor i have to connect the wiring harness for the old one to the new bosch one.. on the plug it has 2 black a white and a green.. on the o2 sensor it has 2 white a black and a gray... the instructions are not staright forward and i cant figure them out... please help
i bought the oem one but the wireing plug on the car is female and the oem sensor had a female as well
here is the instructions that came with it: http://www.boschautoparts.com/...l.pdf
Return that Bosch piece of **** back to Autozone and ride down to the Honda stealership and get the proper one. Or if you can't do that, go to an import parts store and get a Denso or NTK/NGK whatever it is one. DO NOT USE BOSCH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy »</TD></TR><TR><TD CLASS="quote">Return that Bosch piece of **** back to Autozone and ride down to the Honda stealership and get the proper one. Or if you can't do that, go to an import parts store and get a Denso or NTK/NGK whatever it is one. DO NOT USE BOSCH.</TD></TR></TABLE>
that's pretty much sums up the whole bosch deal with honda electronic.
on obd1 and non ulev/sulev car you might get away with it, but later model accord will still throw a heater circuit code
patastinky
Jul 19, 2005 01:24 PM
