Drag racing isn't THAT easy.....help me.
Finally got a few runs under my belt and I'm slightly disappointed.
Car is an 88 CRX with a 97 JDM B18c (R), stock header, chipped p28, 2.5 in exhaust and an intake and that's about it for power. 4.7 final drive. Car weighs 2130 with me in it.
This is from Englishtown last night:
1st run
Right lane) 85 degrees and high humidity
20psi on Dunlop FM901's
RT--->0.861
60---->2.277
1/4---->13.910
MPH--->102.94
2nd run: (left lane) 83 degrees and humidity
16 psi on the tires
RT---->0.397
60----->2.463
1/4---->14.092
MPH--->103.46
3rd run: (Right lane ) 83 degrees and humidity
16 psi on the tires
RT--->0.214
60--->2.263
1/4--->14.325(missed 2nd gear and sloppy 3 to 4 shift)
MPH--->102.97
4th run
Left lane) 82 degrees and humidity
16 psi on the tires
RT---->0.059
60--->2.596
1/4---->14.157
MPH---->103.97
Any tips, pointers, advice, criticism is appreciated.
1st run
Right lane) 85 degrees and high humidity20psi on Dunlop FM901's
RT--->0.861
60---->2.277
1/4---->13.910
MPH--->102.94
16 psi on the tires
RT---->0.397
60----->2.463
1/4---->14.092
MPH--->103.46
16 psi on the tires
RT--->0.214
60--->2.263
MPH--->102.97
4th run
Left lane) 82 degrees and humidity16 psi on the tires
RT---->0.059
60--->2.596
1/4---->14.157
MPH---->103.97
Dont worry so much about the reaction time, the clock doesnt start until u cross the line. Also playing with launching, with your weight and power band im guessing 4 grand would be perfect.
I'm having trouble keeping those tires from spinning, even with an LSD. My first run was the quickest and I kind of rolled off the line. I never launched any higher than 3k any run.
i usually dont blame tires for not-so-great 60fts, but, in a car THAT light with as much power as you have, you probably arent going to be able to pull much better than a 2.2 60ft (which isnt bad at all considering), unless you put something stickier up there. more practice and seat time will definetly have you running better times. try to scoop as set of drag radials or slicks, at least that way your practice will be worthwhile and not so random when the car spins or bogs
hope that makes sense
also looks like you may have aired the tires down TOO much since your 60ft's got considerably worse after you dropped the pressure further. you lost 60ft time consistantly, that leads me to believe 16psi might be a lil less than optimum. just an observation
hope that makes sensealso looks like you may have aired the tires down TOO much since your 60ft's got considerably worse after you dropped the pressure further. you lost 60ft time consistantly, that leads me to believe 16psi might be a lil less than optimum. just an observation
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtistile »</TD></TR><TR><TD CLASS="quote">i usually dont blame tires for not-so-great 60fts, but, in a car THAT light with as much power as you have, you probably arent going to be able to pull much better than a 2.2 60ft (which isnt bad at all considering), unless you put something stickier up there. more practice and seat time will definetly have you running better times. try to scoop as set of drag radials or slicks, at least that way your practice will be worthwhile and not so random when the car spins or bogs
As far as a 2.2 being the best you can do, maybe in a heavier car but not yours... this guys wrong on that point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">I'm having trouble keeping those tires from spinning, even with an LSD. My first run was the quickest and I kind of rolled off the line. I never launched any higher than 3k any run. </TD></TR></TABLE>
The key is learning the car and do u have any form of a 2 step? My hatch with me in it weighs 2275 and i cut consistent 2.0s even hit a 1.8 miraculiously on AVS ES 100s. My best advice is practice.
</TD></TR></TABLE>As far as a 2.2 being the best you can do, maybe in a heavier car but not yours... this guys wrong on that point.
what's he gonna 2-step at? 2000rpm? i wanna see vids or something of a 1.8 on regular tires. ive pulled 2.0s in a 3000 pound car on all season tires, but i had a bit of torque to work with while slipping the clutch. with hondas it just seems you are either going to spin hard, or bog hard...not much torque to work with. im just speaking from the experience i've seen. i have never seen a 1.8 in a light car on normal street tires. show me otherwise
my buddy pulled 1.9x 60's on his gsr hatchback. it was fully gutted and was cammed. ran 13.6 at 100-102 or something like that. dont remember the exact number
make sure when you role thru the water box, you do a burnout.. street tires really shouldnt be burnout too much but you got to get that water off the tires. get them to smoke abit to dry them off, and carry the burnout thru the lane as far as you can. this will help dry the tires and pick up VHT to get them nice and sticky
then work on your launchin techniques. different clutch let outs and such. dont drop pressure too much. keep your tire pressure up around 20-25 or w/e u run on the street. too little pressure will hurt your launch.
you should beable to creep out 1.9x 60 foot. that will get you deeper in the 13's for sure! and hit your shifts
what rpm are you trapping at with those 4.7 final drive gears? what size tires? seems like it would be a good combo for your setup with the right tire size
next on the list of your mods should be drag radials.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Orr89rocz »</TD></TR><TR><TD CLASS="quote">my buddy pulled 1.9x 60's on his gsr hatchback. it was fully gutted and was cammed. ran 13.6 at 100-102 or something like that. dont remember the exact number
next on the list of your mods should be drag radials. </TD></TR></TABLE>
I went around the water box for each run and the tires are 195/50(?) on Konig heliums (15x6.5).
Crossing the line I was somewhere around 8k rpm in 4th gear.
Crossing the line I was somewhere around 8k rpm in 4th gear.</TD></TR></TABLE>
I didnt believe in it, but believe it or not a 2nd gear burn out did wonders for my times, i first applied a burn out in second and then i busted out taht 1.860ft.
Also for the none believers i ran the fasted time so far in my K20R swap in EG hatch 12.70@111 basically 12.6 on 195/50/15 AVS ES 100s. I ran the 1.8 at another track in NJ where the track conditions are heavily full of rubber as they never clean the track and just keep piling on the VHT over the old burned rubber.
Thats partly how i pulled that time, but on that run i hit 12.8 because as i hit top of third i got a CEL which caused me to finish 12.8@102. When comparing the times to my 12.6 run and looking at the 330 and with the 60 fts in i should have finished the run with close to a 12.4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mportbusta »</TD></TR><TR><TD CLASS="quote">u think drag racing aint easy? try pimpin</TD></TR></TABLE>
God dman right, sometimes u gotta punch a bitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego »</TD></TR><TR><TD CLASS="quote">
Which other track? Atco???
I do get a CEL for TPS sensor towards the end of my run and reset it after each run, but I didn't think that would have any effect on my time due to being WOT.
I do get a CEL for TPS sensor towards the end of my run and reset it after each run, but I didn't think that would have any effect on my time due to being WOT.</TD></TR></TABLE>
Yep atco is wherei busted out the 1.8. Such good traction i broke a axle by the wheel hop in second!
Yea i get teh high voltage TPS CEL during WOT in third, it makes me go instantly into limp mode where the car just feels like it falls on its face.
Yea i get teh high voltage TPS CEL during WOT in third, it makes me go instantly into limp mode where the car just feels like it falls on its face. </TD></TR></TABLE>
Yea, Atco is much closer to me and I intend on making at least one trip there.
So the code 7 does affect performance? I didn't notice any considerable difference once the CEL comes on. How can you prevent it from happening?
It all depends on what your trying to accomplish. You can make consitant runs even spinning. If you want better e/t. You should go around the water. You want to your burnout on the dry concrete. actually try to do two burnouts. Don't forget to lower your tire pressue. Good luck.
i have the same tire Fm901 195/50/15 and i have a type r with the jdm b18c. Best time was 2.2 60" 14.1 100mph with 40 psi. Launching about 4-4.5 rpm.
+1 on the tire pressur being too low for a DOT tire. anything lower that 20-22 and you will actually cup the belts and only the outer portion of the tire will make contact. So a 195 tire become a split 25.
With your trap speeds, I would say "screw it" and borrow a buddy's slicks.
Go run some high-12's, low-13's.
<-- I can't launch on street tires either. So when I'm on them, I just leave at idle. Look at my sig.
That was leaving at idle (the 14.2 pass)
Good luck.
That was leaving at idle (the 14.2 pass)Good luck.
