Power Steering leak!
Old Aug 4, 2006 | 11:42 PM
fackyou's Avatar
Default Power Steering leak!
I'm leaking power steering fluid, but i don't know where to check for possible leaks, anyone have an idea. Thanks for the help
Old Aug 5, 2006 | 01:14 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: Power Steering leak! (jdmitr03)
well you start by checking the hoses that connect the pump and resevoir and then and then also check back behind the motor where the hoses connect to the actually steering thangamajang. can you see where the fluid is coming from? have you even looked at it?
Old Aug 5, 2006 | 08:45 AM
eg6sir-s's Avatar
Default Re: Power Steering leak! (God.Loves.Ugly)
you probably need a pwr steering pump rebuild seal kit from honda
Old Aug 5, 2006 | 10:22 AM
fackyou's Avatar
Default Re: Power Steering leak! (eg6sir-s)
i tried checking, but the fluid is spread everywhere under the car, so I can't pin point where exactly. I just got the resvoir replaced and sealed, where is the pump located? Maybe thats the problem? thanks
Old Aug 6, 2006 | 12:40 PM
CASTUDILLO01's Avatar
what year car. the 90-93 tegs are prone to leak under the car in the power steering rack lines. cut the lines and use rubber hose. want to do it right get the metal lines from the dealer and replace all 3 lines.. also high pressure line leak also but no to common.
Old Aug 6, 2006 | 01:29 PM
sirg-vtec's Avatar
Follow the lines.
blackj30_a
Jun 2, 2022 06:16 PM
dcarey
Jun 10, 2017 08:17 AM
oneheadlight
Nov 22, 2015 05:31 AM
darcane
Honda Civic (2001 - 2005)
Apr 24, 2014 08:08 AM
roydogg
Jul 17, 2003 11:12 AM
