Motor Mounts
Hey guys i got a 95 GSR that i am doing a build up and i pulled the motor and its just sitting in the garage. I was wondering which motor mounts do i need to get to put it in my 97 civic hatchback? i don't want to go and buy hasport because i will pull it back out and put it back in the teg when its done. also i heard that i could use the A/C bracket for a P30 del sol to mount the D16 a/c compressor to the B16 is that true or is it another bracket.
99-00 si driver side mount bracket(NOT THE MOUNT) you can reuse your stock mount.
99-00 si rear tranny mount bracket
99-00 si or DC teg shift linkage
these are just the minimum.
great swap article: http://www.phear7imports.net/trey/6gen/
ANGELIQUE
Mar 15, 2005 12:25 PM
