removing rear garnish???
Old Aug 4, 2006 | 07:10 PM
90jdmcrxdude's Avatar
Default removing rear garnish???
I got a new one of those glass pieces that has the Si sticker on it, because my old one was all crappy looking. I was just now trying to figure out how to remove the current one, does anybody know I cant figure it out.
Old Aug 4, 2006 | 07:37 PM
E_F_9's Avatar
theres some nuts on the inside of the hatch area behind the panels.
Old Aug 4, 2006 | 10:07 PM
La EF-8's Avatar
Default Re: removing rear garnish??? (90jdmcrxdude)
i feel your pain man i looked for 2 hours before i found mine
Old Aug 5, 2006 | 07:36 AM
Default Re: removing rear garnish??? (La EF-8)
I just said expletive it and pryed it off with a screw driver, the new one just had clips that were gonna hold it in so I figured the old one was the same. All the clips broke, but I just glued them back on in case I wana try to sell it. New one looks amazing.
Old Aug 5, 2006 | 10:56 AM
92integra_gs's Avatar
rear garnish is held by 8 mm nuts.... just prop out the rear panel and just locate the nuts... there is approx 6-8 of them... dont remember the exact #... and also dont forget to disconnect the wiring... its pretty easy...
Old Aug 5, 2006 | 03:27 PM
Default Re: (92integra_gs)
No the rear garnish is the small windows on the left and right side in the rear of the car one says honda and the other says Si. Its the little triangular pieces.
Old Aug 5, 2006 | 07:04 PM
ahh.... i had to use two flat head .... one to pry and carefully lift the small window... and then the other flathead > try poking it so the lock will be off....
try working top first... then work your way to side which has more room.. ex...if its the left side work the right and vice versa....
dreadhead89
Jan 27, 2009 10:18 PM
Ricey McRicerton
Apr 26, 2007 05:27 PM
90jdmcrxdude
Aug 9, 2006 11:05 AM
PURO~SURCAL
Apr 28, 2006 05:03 PM
crx_ef8
Dec 31, 2002 07:00 PM
