WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 1999-20
Old Aug 4, 2006 | 06:43 PM
alien's Avatar
Default WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 1999-20
WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 1999-2000 civic si????? .. i was also told a shift box? whats a shift box? and which one could i fit on that 99-00 civic si?
Old Aug 4, 2006 | 06:46 PM
Miracle's Avatar
Default Re: WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 199
A shifter box is the housing that holds the shift lever. You can find the box you need in a car like mine, or an RSX-s. Ill look for a pic. Youll need to do a little custom fab work to get that shifter box in your car.
I believe Hasport makes custom stuff for the EM1, axles, mounts ECU harnesses and such.
<U>EDIT:</U> Heres a pic. You will need the white plastic box and the cables coming from it to make it work in your ride...
Old Aug 4, 2006 | 08:35 PM
Slopoke's Avatar
For all the info you need, search through the hybrid forum.
Its all been covered before.
Old Aug 4, 2006 | 09:45 PM
pkdog167's Avatar
I know you need a custom mount, I saw it on Super Street or some magzine...
Old Aug 4, 2006 | 10:52 PM
Rednas's Avatar
Hasport has the answers to all your questions.
Old Aug 4, 2006 | 10:57 PM
Rednas's Avatar
http://hasport.com/catalog/pro...id=38
mounts
http://hasport.com/catalog/pro...889c1
axels
header
everything is available just need to know where to look.
alien
12
Aug 6, 2006 09:09 PM
crx4ever
Jun 12, 2006 09:45 PM
type Gendy
Jan 13, 2006 11:02 PM
TypeR0207
Aug 9, 2001 02:22 PM
