WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 1999-20
WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 1999-2000 civic si????? .. i was also told a shift box? whats a shift box? and which one could i fit on that 99-00 civic si?
Re: WHAT kind of Mounts, harness, axles, transmission, shift cables, when doin a K20A2 swap into 199
A shifter box is the housing that holds the shift lever. You can find the box you need in a car like mine, or an RSX-s. Ill look for a pic. Youll need to do a little custom fab work to get that shifter box in your car.
I believe Hasport makes custom stuff for the EM1, axles, mounts ECU harnesses and such.
<U>EDIT:</U> Heres a pic. You will need the white plastic box and the cables coming from it to make it work in your ride...
I know you need a custom mount, I saw it on Super Street or some magzine...
http://hasport.com/catalog/pro...id=38
mounts
http://hasport.com/catalog/pro...889c1
axels
header
everything is available just need to know where to look.
mounts
axels
header
alien
12
08-06-2006 09:09 PM
WHAT kind of Mounts, harness, axles, transmission, shift cables, shift box, when doin a K20A2 swap i
alien
08-05-2006 11:03 PM
crx4ever
06-12-2006 09:45 PM
TypeR0207
08-09-2001 02:22 PM
