Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help with picking a class.
Old Aug 4, 2006 | 05:31 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Help with picking a class.
I know I know I'll be told to read the rule book, but I have already and that's what my question is about.
I have a jimfab traction bar on my crx and for the street prepared class it says in the rule book that modification of subframes is allowed but bushings must not be replaced with solid metal bushings. But then later on it states that traction bars are allowed in the street prepared class. So I just want to know if my traction bar is allowed in street prepared since it replaces the bushings with metal joints. Thanks.
Old Aug 5, 2006 | 01:43 PM
ILcrxsi1's Avatar
Default Re: Help with picking a class. (ILcrxsi1)
46 views and no answer I guess this is either a really good question or a really dumb question
Old Aug 5, 2006 | 02:02 PM
Jaker's Avatar
Your traction bars are not allowed in Street Prepared or Street Modified, because it replaces the "subframe". The subframe is not allowed to be replaced. You are also not permitted solid metal bushings in Street Prepared. You are permitted the solid metal bushings in Street Modified, but not the replacement of the OEM subframe.
Old Aug 5, 2006 | 02:21 PM
ILcrxsi1's Avatar
Default Re: Help with picking a class. (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Your traction bars are not allowed in Street Prepared or Street Modified, because it replaces the "subframe". The subframe is not allowed to be replaced. You are also not permitted solid metal bushings in Street Prepared. You are permitted the solid metal bushings in Street Modified, but not the replacement of the OEM subframe. </TD></TR></TABLE>From what I've been reading it doesn't even look like it's allowed in prepared not without a penalty anyway. And prepared and modified are pretty hardcore classes too which need added safety ****.
Old Aug 6, 2006 | 12:37 PM
88 rex's Avatar
D mod like the rest of us with aftermarket crossmember.
Jdmb18c5EG
Sep 19, 2006 01:42 PM
cbp_crx
Sep 16, 2006 07:34 PM
stockredej1
Dec 11, 2005 02:08 PM
