Bad Vibration under 50% or more acceleration but only in 3rd, 4th, and 5th gear
Old Aug 4, 2006 | 05:27 PM
slowpokecivic's Avatar
Default Bad Vibration under 50% or more acceleration but only in 3rd, 4th, and 5th gear
its a weird problem...
i searched through the archives and it seems to be cv joint or a problem with the driveshaft or even a problem with the axles...
what i dont get is why it only happens when im accelerating in 3rd 4th and 5th gear.
i can rev out 1st gear with no problems, no vibrations whatsoever. well minus road conditions.
if anyone can give me a definite answer that would be great...
Old Aug 4, 2006 | 09:29 PM
Default Re: Bad Vibration under 50% or more acceleration but only in 3rd, 4th, and 5th gear (SLoWpOkECiViC)
bump for a solution...
im thinking it might be axles...i need to see which speed its happening at...
its definitely not occuring from a dead stop or even through first. its a bit noticeable during 2nd gear, but all hell breaks loose when i get into 3rd...
Old Aug 4, 2006 | 10:12 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLoWpOkECiViC &raquo;</TD></TR><TR><TD CLASS="quote">
Lol. CV joint, drive shaft, and axle are all the same thing.
Im 99.9% sure your problem is a bad inner CV joint. Just replace the whole axle.
Old Aug 5, 2006 | 10:00 PM
Default Re: Bad Vibration under 50% or more acceleration but only in 3rd, 4th, and 5th gear (Slopoke)
haha, didnt realize its all one thing...
now i understand why it happens only in those gears...its when im going a certain speed. its about 55mph and above where it gets pretty bad.
going tomorrow to get everything replaced hopefully that will fix the problem...anyone have any recommendations?
Old Aug 5, 2006 | 10:25 PM
Paxil4x4's Avatar
Either axle, mount or tire
Old Aug 5, 2006 | 11:19 PM
Default Re: Bad Vibration under 50% or more acceleration but only in 3rd, 4th, and 5th gear (packthis)
its definitely not the tires...this vibration is REALLY bad, plus i mounted and balance my own tires...
Old Aug 5, 2006 | 11:26 PM
LERRY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
Im 99.9% sure your problem is a bad inner CV joint. Just replace the whole axle.</TD></TR></TABLE>
new axle
Samuels
Aug 15, 2009 05:57 PM
lalaine17
Apr 12, 2006 09:32 AM
Euro98ITR
Apr 14, 2005 09:40 PM
integration
Nov 18, 2002 12:54 PM
