why a knock at cold idle>?
Old Apr 24, 2002 | 02:08 AM
MikeSarr_GSR's Avatar
Default why a knock at cold idle>?
setup:
.44mm effective gasket thickness
B18C head and block
Endyn .5 over ex valves
Honda Type R in valves
+3 intake, +2 ex cams
no thermostat (mine was stuck shut, removed it)
18BTDC at 500rpm +/- 50rpm
knocks on rev between 1K and 1.5K, once it gets hot
it goes away. while cool, it knocks. Could this be the
sign of a weakened rod bearing wanting to get loose?
I just changed over to syn lube at 40K. I cleaned
everything well, ATF in upper, drain, fill with 10-30,
drive, bring back idle with ams engine flush, drain,
fill with 10-30 drive for 50 miles, drain, change filer
to ams sdf20, fill with ser 2000 0-30w TCO.
thanks for the time to consider this...
Old Apr 24, 2002 | 02:36 AM
rainforest's Avatar
Default Re: why a knock at cold idle>? (MikeSarr_GSR)
yeah man your going to have to tell us more but here are 2 things
could be rod bearing or piston slap. but explain how hard the noise is.
Old Apr 24, 2002 | 06:37 AM
StyleTEG's Avatar
Default Re: why a knock at cold idle>? (rainforest)
Kinda sounds like piston slap, its actually pretty common in tegs from what I have seen
Old Apr 24, 2002 | 08:01 AM
X2BOARD's Avatar
Default Re: why a knock at cold idle>? (StyleTEG)
I've never seen it in a stock teg.... there's something he's not telling us. Are you running stock pistons ? Piston slap typically does not happen with cast pistons.
Souls
Jul 15, 2018 10:43 PM
amtrak23
Oct 27, 2015 07:49 AM
konvikt
Apr 2, 2012 09:08 PM
AK77
Dec 5, 2008 07:32 AM
