b18 head - b16 block possible??
Old Apr 24, 2002 | 12:30 AM
ang's Avatar
ang
Default b18 head - b16 block possible??
is it possible to put a b18 head on a b16 block??
if so what are the pros and cons??
Old Apr 24, 2002 | 12:43 AM
Katman's Avatar
Default Re: b18 head - b16 block possible?? (ang)
b18c vtec head or non-vtec (b18a/b) ?
be more precise with your questions, please..
Old Apr 24, 2002 | 08:24 AM
ang's Avatar
ang
Default Re: b18 head - b16 block possible?? (Katman)
sorry guys,
yeap is B18c Vtec head - B16A Vtec Block JDM
Old Apr 24, 2002 | 08:57 AM
Quik Chris's Avatar
Yeah, I know a couple guys that do this garage parts-bin special.
Old Apr 24, 2002 | 12:14 PM
Katman's Avatar
sorry guys,
yes, it's possible and it's a cool setup actually if you run a Skunk2 manifold on the GSR/P72 head. Actually, running the Skunk2 manifold is manditory, because if you run the GSR 'snail shell' manifold, you could run into clearance problems since the deck heighth on a B16A is 7mm shorter than a B18C's block. I know someone who's used the GSR manfold though, and it doesn't perform that great in comparison to a Skunk2 manifold. You won't have any clearance issues with teh SKunk2 manifold either. You should try it, and run a thinner headgasket while your at it....its a cool little setup for a B16A. I'm planning to do this setup when i get my newly-acquire B17A block
You'll gain compression by just bolting this head onto your b16a block.
Old Apr 28, 2002 | 04:32 PM
B_CRUZ!'s Avatar
i just sold this swap(same set-up) to one of my friends and the motor is dope. Skunk2 mani, first gen B16A block and a P72 head and he is usinga ITR intake cam. he just finished the swap and the motor loves to be revved.
Old Apr 28, 2002 | 06:23 PM
allmtr's Avatar
Default Re: b18 head - b16 block possible?? (B_Cruz)
higher compresion
allstarr7
Jan 11, 2009 03:17 PM
jdmbuilt
12
Jun 17, 2003 07:15 PM
ricodemus
Jan 20, 2003 04:04 PM
salbaje
Nov 19, 2002 06:41 PM
integ94
Jul 13, 2001 06:07 AM
