how do i put a 2002+ RSX Type S Motor in a 99-00 Civic SI?
Old Aug 4, 2006 | 02:25 PM
alien's Avatar
Default how do i put a 2002+ RSX Type S Motor in a 99-00 Civic SI?
what do i need inorder to swap this motor into a 1999-2000 civic si? what motor mounts? wiring harness.. etc.?
Old Aug 4, 2006 | 03:43 PM
Miracle's Avatar
Default Re: how do i put a 2002+ RSX Type S Motor in a 99-00 Civic SI? (sinanovicha)
Mounts, harness, axles, transmission, shift cables, shift box, ECU, PS and AC lines if you want to retain them.
Thats all I can think off off hand.
Old Aug 4, 2006 | 06:44 PM
alien's Avatar
WHAT kind of Mounts, harness, axles, transmission, shift cables, and whats a shift box?
Old Aug 4, 2006 | 06:52 PM
Reborn's Avatar
Reborn_
get hasport mounts, and the rest should be oem rsx-s
Old Aug 4, 2006 | 06:53 PM
Miracle's Avatar
Default Re: (sinanovicha)
Shifter box, aka shifter housing:
You will need the white palstic box, the lever, and the cables.
Hasport makes most of the stuff you need, such as axles, mounts, ECU harnesses, and a header and downpipe to transplant the K into your civic.
Old Aug 4, 2006 | 06:58 PM
ballerchild's Avatar
if you're really serious about this swap.. try k20a.org
Old Aug 4, 2006 | 07:46 PM
alien's Avatar
motor just drops in ? how much u think all those parts cost at hasport?
Old Aug 4, 2006 | 07:58 PM
Miracle's Avatar
Mounts
Axles
Harness
Most of the other stuff, shift linkages, and PS lines and AC line will need to be OEM RSX-s or 02-05 Si.
Old Aug 5, 2006 | 03:57 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinanovicha &raquo;</TD></TR><TR><TD CLASS="quote">motor just drops in ? how much u think all those parts cost at hasport?</TD></TR></TABLE>
A lot. Do some research before you waste our time asking questions that could have been answered by spending two minutes on Google.
Old Aug 5, 2006 | 05:33 PM
MITeggy17's Avatar
Default Re: (Archidictus)
I know it isn't the same, but in this months Honda Tuning, with the black Del Slo on front, inside there is an article on how to K swap a CRX, maybe that could help you out a bit. . Its a good 5 pages.
Old Aug 6, 2006 | 07:37 AM
Klutch-Control's Avatar
Hope you have a lot of free time available... I am in the process of helping a friend complete this in his 95 coupe. Lets just say it hasnt been plug and play. I just hope your doing most of the work yourself, because if you have to pay for labor and everything else.. I hope you have deep pockets. Goodluck though
Old Aug 6, 2006 | 01:45 PM
rodimus's Avatar
Default Re: (ballerchild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild &raquo;</TD></TR><TR><TD CLASS="quote">if you're really serious about this swap.. try k20a.org</TD></TR></TABLE>
http://www.k20a.org
Old Aug 6, 2006 | 09:09 PM
JDMITRTuner's Avatar
Its not going to be a direct bolt on the setups reversed so what you would have to do is basically do custom motor mounts.
1997 gsr
19
Apr 20, 2009 10:41 AM
alien
Aug 4, 2006 10:57 PM
SuperTwinz
Jul 29, 2006 02:11 AM
b18cInside
Dec 8, 2002 11:48 PM
