Stock sleeve B16 440whp Dyno Chart
I have had the chance to post this until now. Car ran 11.4@125 and a best mph of 127 so far, car hasnt been hooking at the local tracks. Anyways just figured i would share the new numbers.
Old setup was:
Inline pro mani
2.5''dp
sc6152e
380whp, 246wtq on 20psi
New setup:
Full-Race top mount
4'' dp and exhaust
sc6152s
tuned to 11:8 A/F on 20psi boost
Old setup was:
Inline pro mani
2.5''dp
sc6152e
New setup:
Full-Race top mount
4'' dp and exhaust
sc6152s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO »</TD></TR><TR><TD CLASS="quote">ENJOY HER WHILE SHE LAST!
We were able to get a stock sleeved block up to almost 400 but she didn't live long!
Thanks guys, as far as the motor lasting the tune is pretty conservative so i dont think we will have a problem. This motor is already a year and half old with 25,000 miles on it and was making 380whp for a year or more. Compression #'s and leakdown are perfect. My engine builder has done several motors like this that have lasted 70,000+ miles and 500whp.
</TD></TR></TABLE>Thanks guys, as far as the motor lasting the tune is pretty conservative so i dont think we will have a problem. This motor is already a year and half old with 25,000 miles on it and was making 380whp for a year or more. Compression #'s and leakdown are perfect. My engine builder has done several motors like this that have lasted 70,000+ miles and 500whp.
94 civic ex coupe
2650lbs with driver
81.5mm B16 stock sleeves
SC61
11.3@126 on old setup
New setup = 10's soon???
you know every time i see people running low #'s with heavy cars, and have under 500hp I'm impressed.
2650lbs with driver
SC61
put springs and retainers in it, with that turbo, that car will make power to 9500 if done right. IM/cams?/valvetrain/etc. mine makes peak at 10k, i just havent revved it pat there yet
Its already got good valvetrain in it, stock cams though. As far as the fuel setup its just a walbro 255hp pump, b&m regulator (stock fuel rail) and PTE 880cc injectors. I will just make another trip to the dyno and rev it higher just to see.
im running 1000cc injectors at like 65% duty. and i have gsr cams. with that setup and like 24 psi, you COULD make nearer to 490ish. depends, when i finally got into the higher efficiency on my turbo, it started making 24hp per lb
Well i have been working on the traction problems, got it down to a decent number for now. Car went 11.00@130 now. I have a few more things im gonna try with the suspension to get into the 10's, at this point i think if i can cut the 60ft from a 1.73 to about a 1.67 it should do a solid 10.90 pass.
Im looking at getting a truck soon so this will be the weekend car so once that happens i think we will rev it a little higher and turn the boost up to 25psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben »</TD></TR><TR><TD CLASS="quote">Nice numbers. Just dyno'd mine on some more boost and race gas last night and made 567 so those stock sleeves will take some boost!</TD></TR></TABLE>
What boost are you running now? Thats gonna be sick man, good luck and i cant wait to see how you run with that much power.
