How to take out door panels???
any help
i know its easy
just want some simple instructions on how easy it is
dont' wanna mess it up
the seats no prob
but i aint' so technical
any help on this one folks
i know its easy
the seats no prob
Along the sides of the doors there are screws, unscrew those and maybe the ones where your doorlock is as well as changed holder (or whatever you call it). I'm pretty sure that's it.
huh
to take the door panel off
i need to take out the change holder
dont' get it
i know
how many screws are there
does anyone know
dont' get it
i know
does anyone know
Huh? There's 2 screws from what I remember...the rest are clips that *pop* off when pulling on the door panel. There's a little more to this than that but I'll show you (itr-j) on Friday.
3 screw to take out. one under a tiny plastic flap under the door opener, lock area.
one in the grab handle(coin holder
the other is a plastic screw/fastener at the upper front of the panel.
from that point, it is a matter of pulling the panel from the metal door. it's held on by plastic inserts. start from the bottom edge of the door panel. just get a firm grip and firmly jerk the panel outward. the plastic inserts should pop out. work your way along the bottom. must be about 7-8 of those. once the panel is loose on the bottom, the top edge can be lifted upwards and back. careful of that triangle piece of the plastic on the backside of the mirror area.
undo the connectors on the back of the panel and it's off.
good luck. tricky part is getting the panel back on.
[Modified by kkim, 5:26 AM 4/26/2002]
). the other is a plastic screw/fastener at the upper front of the panel.
angle the door panel on a really sharp angle (>50) and try to put the corner near the mirror back on first. find u'r spot by looking throught the hole where the door handle would be. once u ge tthe corner in the rest slisp right in.
the key is not to try to put the door on all at once.
The first time i did it was hard to get the panels back on. I figured out how to do it now and it just glides right in.
USDM DC4
May 19, 2007 06:19 PM
Inaniac
10
Jun 23, 2002 06:24 PM
