Jdm frontend conversions on a gsr
did any body have trouble with ac lines that go around the front of the rad support,
and did any one have trouble with ac line in the way of oem hid ballast?
i don't have ac anymore, but at the time the only thing that gave me a problem was the lines behind the driver side ballast, which i just disconnected and pushed out of the way. Also the usdm washer tank will give u a problem too. The ones in the front shouldn't. Also if u have a pre - 98 forget about the ballast fitting on the passenger side. As for the install, use the 'T' off the rad support.. don't cut your whole support off, it's not needed, and is way more difficult. There are how-to's on how to do it with the 'T' part of the support. Just do a search in the archives.. Check out my myspace for some finsihed product.
