Suspension & Brakes Theory, alignment, spring rates....
polyeurothane vs. butyl rubber: which is better?
Old Aug 4, 2006 | 12:00 AM
gyrmaersk's Avatar
Default polyeurothane vs. butyl rubber: which is better?
I have heard it said that butyl rubber flexes less. And I have heard others say that poly is better for bushings, less flex. Is this on a per application basis (trailing arm bushings, sway bar, etc.) or what?
What's the deal, Honda Nation?
Old Aug 4, 2006 | 06:58 AM
AutoXer's Avatar
Default Re: polyeurothane vs. butyl rubber: which is better? (gyrmaersk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gyrmaersk &raquo;</TD></TR><TR><TD CLASS="quote"> poly is better for bushings, less flex. </TD></TR></TABLE>
Also harsh, noisy and wear faster. I use OEM for bushings. Never use poly on the RTA, as it can cause suspension bind. Poly is pretty worthless for a DD.
Old Aug 5, 2006 | 08:38 PM
bpr0422's Avatar
Default Re: polyeurothane vs. butyl rubber: which is better? (AutoXer)
poly just reqires a little more care than rubber ones...
u need to be able to lube em with marine grease at least once a year...
depending on ur driving conditions...
http://www.k20a.org/forum/showthread.php?t=5952
that should help...
imo poly does the job, and lasts longer with care...
Red Balut
Suspension & Brakes
16
Jan 25, 2008 01:17 PM
redman223
Suspension & Brakes
Aug 8, 2007 02:19 PM
SkIp_Civic_Ek6
Jun 9, 2006 09:24 PM
JunIntegra
Suspension & Brakes
Jan 22, 2005 08:19 PM
TeaAddict
Dec 7, 2004 07:21 PM
