how can you tell if shocks are blown?
Old Aug 3, 2006 | 09:41 PM
CivicProject97's Avatar
Default how can you tell if shocks are blown?
let me know thanks.
can you tell by pushing down on them?
Old Aug 3, 2006 | 09:42 PM
SavEM1's Avatar
yes, that would be one way. Being able to push down on them, and the strut not coming back up (or coming very very slowy back up) is a sign of bad..uh ness
xhatchracerx's Avatar
Default Re: how can you tell if shocks are blown? (CivicProject97)
if you push down on them and they dont go back up then theyre blown. usually lots of oil everywhere is a good indicator too. hope that helps
Old Aug 3, 2006 | 09:45 PM
bmoua's Avatar
Default Re: (Hcivic02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 &raquo;</TD></TR><TR><TD CLASS="quote">yes, that would be one way. Being able to push down on them, and the strut not coming back up (or coming very very slowy back up) is a sign of bad..uh ness</TD></TR></TABLE>
yep...
Old Aug 3, 2006 | 09:48 PM
Default Re: how can you tell if shocks are blown? (xhatchracerx)
so if they come up slowly theyre blown or just bad?
Old Aug 3, 2006 | 09:51 PM
Slopoke's Avatar
I've never seen a bad strut that wont come back up(when the car is pushed down). The shaft would have to be seized in the strut housing pretty badly.
If you push down on your car and it doesnt come back up, you most likely have a spring problem. Not a strut prob.
Usually, when you bounce a car with bad struts, it will continue to bounce after you stop pushing on the car.
A car with good struts should settle very quickly once you stop bouncing it.
Also, bad struts can make alot of noise when they are jounced(but they dont always).
Old Aug 3, 2006 | 09:52 PM
Default Re: (Slopoke)
yeah but the shocks arent installed on the car yet.
so if i push them down and they slowly come back up whats that mean?
Old Aug 3, 2006 | 09:53 PM
SavEM1's Avatar
Back with my RX7 I took off mine and pushed them down, took them a good 3-4 minutes for them to come back up all the way
Old Aug 3, 2006 | 09:55 PM
so what does that mean? good? bad? okay?
Old Aug 3, 2006 | 09:57 PM
potential's Avatar
yes that is how its done go to all the corners of your car and push down several times then just see how many bounces after that it takes for the corner of the car to settle. im not 100% sure about how many bounces means its blown or bad but any more then 4 then u should replace the shocks.
Old Aug 3, 2006 | 10:03 PM
Paxil4x4's Avatar
Default Re: (potential)
If the car bounces alot the shocks are blown. If the car oscillates after going over a bump the shocks are blown. The signs are leaking oil, wear marks on one side of shock shaft, smashed bump stops, ripped upper mounts are all signs of worn shocks
Old Aug 3, 2006 | 10:04 PM
Default Re: (packthis)
i understand. <U>but my situation is i havent mounted it on the car yet.</U>
so im just pushing it down if it slowly goes up what does that mean?
Old Aug 3, 2006 | 10:27 PM
Slopoke's Avatar
Default Re: (CivicProject97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicProject97 &raquo;</TD></TR><TR><TD CLASS="quote">i understand. <U>but my situation is i havent mounted it on the car yet.</U>
so im just pushing it down if it slowly goes up what does that mean?</TD></TR></TABLE>
Means they're probably fine.
Thats what new struts will do.
Old Aug 3, 2006 | 11:13 PM
Paprika's Avatar
bolt each strut to a pogo stick and see if you can then go pogo... if you can't pogo then the strut is good.
Nah jk
But for real I think if the shock resists quick movement (i.e. you try to extend it fast or compress it fast) it's good. If it doesn't pose much resistance to the quick movements such as a sudden comression or extention then it can't possibly absorb the oscillations the spring will attempt to bring about when used on a car.
illagee
Nov 3, 2005 09:35 PM
spddmn124
May 21, 2005 03:07 PM
Soda Popinski
15
Jun 30, 2004 10:04 AM
GARBhatch.
10
Mar 23, 2004 11:49 AM
YoungOne
Feb 16, 2004 12:07 AM
