turn signals
Anyone know how to slow down your turn signal flashes? All my bulbs are working but they still flash quick...Ive heard you can use inline resistors but what size and does anyone know if it works?
thanks
thanks
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
They make a device for this, Its call the run-about. Its a small box that plugs into the scocket that your flasher relay was located. And you can control the flash rate.
NM, I fixed it with 4- 10 watt 1 ohm resistors wired in a series works perfect but if you ever use these resistors they get real hot so mount them somewhere away from plastic or anyhting that wont melt.
rickkane
Nov 29, 2008 11:03 AM
