Suspension & Brakes Theory, alignment, spring rates....
EF Rear Toe Setting
Old Aug 3, 2006 | 05:43 PM
adamkob32's Avatar
Default EF Rear Toe Setting
Is the rear toe adjustable on the EF's? If so how do you go about adjusting it. I've got a fair amount of toe-out in the rear now and I'd really like to take that to 0.
Thanks in advance!!
--Adam
Old Aug 3, 2006 | 06:09 PM
Tyson's Avatar
Default Re: EF Rear Toe Setting (adamkob32)
yes. you adjust this bolt.
but you need to measure it somehow. and if you dont know where to start, then i highly suggest you just take it to any alignment shop and get it done.
PIC Performance's Avatar
It is ajdustable, via the rear toe-link / compensator arm.
Loosen the bolt labeled "compensator arm bolt" in the picture, and the arm will slide side to side. Slide outward = toe out, slide inward = toe in.
Old Aug 3, 2006 | 06:40 PM
adamkob32's Avatar
Default Re: EF Rear Toe Setting (PIC Performance)
Thanks guys. Didn't even notice that was slotted.
--Adam
SleeiNESS
Feb 4, 2012 08:30 AM
brownsEF
Feb 27, 2010 07:01 PM
project-boosteD
Suspension & Brakes
Jan 27, 2009 01:58 PM
goldegg
Oct 18, 2007 07:26 AM
alwaysoverkill
Suspension & Brakes
Jan 13, 2006 07:43 AM
