b16 swap into eg
Old Apr 23, 2002 | 09:37 PM
black92si's Avatar
Default b16 swap into eg
i think i need some help. i'm gonna put a b16a into my 92 si hatch. i've been told that the rear bracket thats on the motor will work and also that it will not work. wtf? i've also been told that i need a map sensor from a 92-95 dx civic or i can use my map sensor from my car. i'm so confused! any help would be apreciated. thanks in advance.
Old Apr 23, 2002 | 10:16 PM
Kamin's Avatar
Default Re: b16 swap into eg (black92si)
you need the mount from a 94+gsr
the map sensor you can use from your stock manifold
i hope you mean a b16 second gen
Old Apr 24, 2002 | 02:48 AM
rainforest's Avatar
Default Re: b16 swap into eg (KAMiN)
yes you need a 94 rear braket don't listen to oter people.
Old Apr 24, 2002 | 06:02 AM
TodaSi's Avatar
Default Re: b16 swap into eg (rainforest)
Will a 99 Civic Si rear bracket work?
Old Apr 24, 2002 | 04:39 PM
TodaSi's Avatar
Default Re: b16 swap into eg (TodaSi)
ttt
Help, anybody know?
Old Apr 24, 2002 | 08:06 PM
owen_the_soyboy's Avatar
not 100% positive, but this info may be in the EG forum thread "B18C5 in Eg Who Has It?"
I am almost positive the rear mounts are the same between 99-00 Si and 94+ teg.
TodaSi, hows it goin?
Old Apr 24, 2002 | 08:08 PM
TodaSi's Avatar
Default Re: b16 swap into eg (owen_the_soyboy)
Pretty good. Starting my swap in the morning Wish me luck!
Old Apr 24, 2002 | 09:16 PM
rca90gsx's Avatar
From what i've been told by a few companies that make mounts, (and this is the combo used on our b16a install on a 92 cx) you have to use a 94 GS-R rear mount and with the first gen series b16a you have to use a 99 civic si drivers mount.
Richie
Old Apr 25, 2002 | 02:06 AM
black92si's Avatar
Default Re: b16 swap into eg (rca90gsx)
thanks for all the help gang! i found out that you do need the gsr rear mount bracket. also found out that i need a map sensor from a 92 civic dx. (the one on the firewall) i have come across one more problem though, which speed sensor do i use with a cable tranny? i'm using hasport's mount kit and cable to hydraulic conversion and i must say that the kit is awsome! just need to get my speedo working
93redcb7
12
Jun 15, 2016 02:22 AM
MysticalMagnet
Feb 16, 2009 06:41 AM
sirt_eg
Apr 13, 2006 02:50 PM
hondahatch741
Oct 14, 2004 04:56 PM
94CivSi
Apr 17, 2003 11:56 AM
