GSR JDM intermittent power trouble
2 years ago i swap a 97 GSR JDM in my RS.
2 monts ago my engine start to loose power in 4000+ rpm. (a VX can pass you)
The ECU and ENGINE are JDM OBD2a.
i check the wiring,make a complete tune up, change the dizzy.
everiting seems to be ok.
Someone else here ever ave the same trouble.
it's intermittent and if i stop the motor and start again the problem is gone for few minute.
tanks!
tanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mathieucivic »</TD></TR><TR><TD CLASS="quote">2 years ago i swap a 97 GSR JDM in my RS.
tanks!</TD></TR></TABLE>
Try disabling the vac line to the secondary runner assembly.
This sounds like it could be related to your VTEC system. Has the computer shown any CELs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
Try disabling the vac line to the secondary runner assembly. </TD></TR></TABLE>
The normal position for the intake manifold is the short runners. Vacuum is applied to close them for low RPM operation. It could get stuck on the long runners (butterflies closed) if the IAB solenoid if sticking ot the vacuum purge is clogged.
No CEL.
Is intermittent and when i close the ignition and restart is ok for some time.
it is possible the ecu tink is kock and retard the timing too much.
The complete tune up is new, fuel filter all sensor check...
i even try a new distributor and the same thing happen.
The knock sensor would intervene at low RPM. Is you ECU stock?
Does the VTEC engage at 4400 RPM like it is supposed to when you have the power problem?
99-SOCAL-EK
Feb 19, 2006 05:43 PM
