question about wire harness
my ecu plugs were cut.
would it be easier to jus cut the plugs from another civic and jus color match them or to take off the whole harness. i went to the junkyard and they told me it would be 25-50 for the harness but its ALOT of work plus i dont know how to remove the dash.
please i really need help on this to get my car running
As long as you get the exact harness plug from the exact matching car than yea is should be a simple color to color match up, lil solder and heat shrink tubing and you'll be set........ just make sure to have a good amount of lenght on the harness you are splicing.
well i have my old shell that i was parting out i cut the plugs off but its a 94 cx and my new car is a 92 cx...so the plugs would be differnt?
does someone have a diagram that shows me shich wire would go to where i'm sure the plugs can't be that different
