16 x 7" rims on dropeed integra, 40 or 45 mm????
Old Apr 23, 2002 | 08:41 PM
H22coupe's Avatar
Default 16 x 7" rims on dropeed integra, 40 or 45 mm????
I searched around a didn't find a good answer. I'm looking to get Slipstreams in 16 x 7 for my GSR that has been dropped about 2 inches (may go more once I get rims and try things out). Should I go with the 40 or 45 mm offset? I know a ton of you are running 16 x 7 rims. By the way, I'm planning on running 205/45/16 tires so feel free to recommend what you've found to be good all around daily driver/occasional track tires.
Old Apr 23, 2002 | 09:13 PM
degradated's Avatar
New User
Default Re: 16 x 7" rims on dropeed integra, 40 or 45 mm???? (H22coupe)
I had 16x7 regamasters with a +45 offset and 205/45 tires, and it was perfect. Dropped over 2" and no rubbing.
Go with the highest offset you can before it interferes with the suspension members/control arms. In my opinion, +45 is perfect. +40 will stick out slightly farther from the body (hard for the human eye to tell, but more prone to rubbing and such)...
Old Apr 23, 2002 | 09:47 PM
Halo's Avatar
Default Re: 16 x 7" rims on dropeed integra, 40 or 45 mm???? (degradated)
third lobe
Mar 22, 2009 09:45 AM
Jaydeep
Apr 22, 2005 09:21 AM
Crxer
Sep 2, 2002 01:15 PM
austrian type-R
May 10, 2002 07:29 AM
