Auto and Manual Axles? Getting Mixed results...
Old Aug 3, 2006 | 12:23 PM
Tonyl507's Avatar
Default Auto and Manual Axles? Getting Mixed results...
I've done some searches, but some contradict each other, and most of the search results are for civics.... anyway...
Swapping a 5 spd GSR motor and trans into a 4 spd Auto LS. Cars are both '97s and both have ABS...
I just need to know, DO I NEED TO USE THE AXLES FROM THE MANUAL? or Can I use <U>just </U>the intermediate shaft from the manual,while re-using the axles from the auto??
Also, some people say they are the same, others say the shafts are different thicknesses? Anyway know the truth?
Modified by Tonyl507 at 1:33 PM 8/3/2006
Old Aug 3, 2006 | 01:55 PM
Tonyl507's Avatar
Default Re: Auto and Manual Axles? Getting Mixed results... (Tonyl507)
bump for a response, some ones gotta know....
Old Aug 3, 2006 | 02:21 PM
gsrghost's Avatar
i dont know the answer to your question but if you dont get an answer i would suggest you swap them out anyways, better safe than sorry.
ProJectCvic's Avatar
you can use the axles from an auto. If you have a manual tranny, you cannot use the auto intermediate b/c it will sit out (towards the firewall) a slightly bit futher. Similarly, if you have an auto you cannot use the manual intermediate. Axles are interchange from either manual or auto
Old Aug 3, 2006 | 02:31 PM
SilverDc2's Avatar
Default Re: Auto and Manual Axles? Getting Mixed results... (ProJectCvic)
^ CORRECT
auto = manual same thing, the shaft is different, you need a speed one, they look almost identical but the back portion where it bolts on is angled different.
i did a auto to manual swap. so its coming from first hand experience and not "i heard it works"
Old Aug 3, 2006 | 02:49 PM
Tonyl507's Avatar
Default Re: Auto and Manual Axles? Getting Mixed results... (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">^ CORRECT
i did a auto to manual swap. so its coming from first hand experience and not "i heard it works"</TD></TR></TABLE>
So you mean the axles are the same, but I need to use the intermediat shaft from the manual(in the pic)???
I broke a tranny differenterial to know this...hahah. Well...now I know this and how to rebuild tranny .
Old Aug 3, 2006 | 03:07 PM
SilverDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonyl507 &raquo;</TD></TR><TR><TD CLASS="quote">
So you mean the axles are the same, but I need to use the intermediat shaft from the manual(in the pic)??? </TD></TR></TABLE>
yea, get a 5speed shaft, hmotorsonline.com sells them for 75 bucks.
the only difference is ABS and non-ABS, reuse your axles if their good.
D16SiHatch
Mar 4, 2008 02:29 PM
InfamousRS
May 13, 2006 11:50 PM
krzyaccord
Mar 31, 2004 03:10 PM
blackZC (W)
Dec 30, 2003 03:52 PM
InfamousRS
Feb 9, 2003 03:57 PM
