A/C belt
ok so it makes this really loud squealing noise only when the ac is on, otherwise it runs fine. belt is not worn out and and its on there snug. i was thinkin and 1 mech. told me that acutally worked on my car before the tensioner needs to be tightened up, thats it plain and simple. another mech that also looked at it said i would have to get a new ac belt before they could tighten it bc the one on there is a little too loose. 3rd mech. said that i should get new ac and alt. belt and that could fix the prob. or it could be somethin with the pressure from the compressor or somethin like that. any ideas?
yea the belt seems to be in good shape, and i was just thinkin it just needed to be adjusted either tightened or loosened. yea i didnt really think about it being too tight, that is a possibility. so i shouldnt have to replace it if its not cracked or worn right? none of the mech. saiid anything about it being a worn or cracked belt. and it blows cold air so i dont think its the compressor at all. should i even worry about how one of the tech. said somethin about the pressure might be too high from the compressor?
Blacknight117
Sep 19, 2011 04:13 PM
superthug
Aug 2, 2008 08:02 PM
Atiyeh
May 30, 2002 03:34 PM
