changed tire size/my speedo isnt reading correct ?
Old Aug 3, 2006 | 08:50 AM
SolBreak's Avatar
Default changed tire size/my speedo isnt reading correct ?
i just put a set of 17" racinghart cp-10 wheels with 215/45 tires on my del sol. ive seen one before, but does anyone know where i can find a chart where it shows the speed the speedo says compared to your actual speed? thanks alot
Old Aug 3, 2006 | 08:55 AM
krisjk2's Avatar
Default Re: changed tire size/my speedo isnt reading correct ? (SolBreak)
http://www.f-body.org/gears/
https://honda-tech.com/zerothread?id=629535
should help you out a bit, just need to find the gearing of your tranny.
Padawan's Avatar
Darth ModerVader
http://www.miata.net/garage/tirecalc.html
I would strongly suggest purchasing tires of the correct size for your application, which your current ones clearly are not.
Old Aug 3, 2006 | 08:58 AM
LowSlow93Sol's Avatar
Default Re: changed tire size/my speedo isnt reading correct ? (Padawan)
http://www.teamdelsol.com/tech...2.zip
ChrisFred96
Sep 26, 2015 06:38 PM
goofygamer
Nov 11, 2010 02:11 PM
jontsi95
Jun 19, 2008 12:24 PM
OldSchoolHatch
Feb 17, 2007 02:39 PM
beoy9
Mar 24, 2005 10:15 AM
