Prelude with Jun p73 ecu?
Old Aug 3, 2006 | 08:41 AM
yellow_R_dragon's Avatar
Default Prelude with Jun p73 ecu?
Hi all, I have a 2000 prelude non sh and was wondering if i could use an obd1 p73 ecu which have jun chip? This ecu was in an integra with harness converter, let me know if it's ok to do this....
Old Aug 3, 2006 | 08:51 AM
prelittlelude's Avatar
Default Re: Prelude with Jun p73 ecu? (yellow_R_dragon)
NO, well not unless you change the injectors..
Old Aug 3, 2006 | 08:59 AM
Chuckles99SH's Avatar
Default Re: Prelude with Jun p73 ecu? (prelittlelude)
removed.. non - sh
Old Aug 3, 2006 | 09:02 AM
Default Re: Prelude with Jun p73 ecu? (Chuckles99SH)
so that's all i need to do? and it should run fine?
Old Aug 3, 2006 | 09:47 AM
v4lu3s's Avatar
RTFM
personally I would not use it, but then again I have never hard of or seen an obd1 p73, after all the first integra type-r ame out in 1996....
Old Aug 3, 2006 | 10:00 AM
true, according to pgmfi.org every p73 was obd2,
Old Aug 3, 2006 | 10:29 AM
i honestly don't know what ecu this really is cuz it has been opened and the serial has been removed.... all i know is it was in a 98 integra gsr and the side of the ecu was writtened p73 and it had a obd2 to obd1 harness converter... let me know what you guys think if it's ok to put this ecu in my prelude... thanks
Old Aug 3, 2006 | 10:58 AM
Eddiebx's Avatar
judging by the fact that you have no clue what the ecu is, i dont think its a good idea to stick it in your car.
Old Aug 3, 2006 | 01:30 PM
IAluder95's Avatar
figure out where it actually came from.
Old Aug 3, 2006 | 04:21 PM
Eddiebx's Avatar
Default Re: (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">figure out where it actually came from. </TD></TR></TABLE>
more importantly find out waht fueland igntion maps are on that ecu, and see if it will be safe to run an h22 wiht it.
NickGREPSMN
May 2, 2013 04:08 PM
RudeLude
Apr 22, 2007 04:57 PM
HKSpowers
Sep 1, 2003 11:33 AM
