rs-r ex-mag
Old Aug 3, 2006 | 08:01 AM
97BB6Type-SH's Avatar
Default rs-r ex-mag
Was lookin into it for my SH and only found it with piping but only found it for the base. does any one know if the bends are that much diff? or does any one have a site that sells it jus the exhaust?
Old Aug 3, 2006 | 09:05 AM
Chuckles99SH's Avatar
Default Re: rs-r ex-mag (97BB6Type-SH)
The bends are the same, The header on the SH is shorter by about 8-10 inches. It is shorter because it has to accomidate the ATTS system. Check out Greddy Evo2 (5th gen) that is made for both the Base/SH the only difference is the "adapter" which is an extension pipe to fit the SH. I'm not sure the actual length you may want to talk to someone at Greddy and see if you can get an answer. I'm not sure if the extension would work for the RS-R but I know that they only make that for the Base.
Old Aug 3, 2006 | 09:51 AM
Default Re: rs-r ex-mag (Chuckles99SH)
thanks...i searched but cant find the adapter alone. if i could get a pic of the adapter i could probbaly get it made.
Old Aug 3, 2006 | 11:27 AM
HxClude's Avatar
Judging by your above post, I think you have it backwards - you don't need to get an adapter made, you need to have some piping cut To make a base exhaust fit an SH, take it to an exhaust shop and have them cut off a section of pipe and weld on a flange that matches to your header.
Also, you do know that the RS-R is temporarily out of production, right? They're making some updates and will be rereleasing it in a few months
roflcopterdown
Sep 30, 2007 06:04 PM
SilentEdge
Jun 11, 2007 11:52 AM
cgap
Jun 24, 2004 10:12 AM
Toda Built
Aug 8, 2003 04:03 PM
Canonm7
Apr 12, 2003 06:05 PM
