can we swap 04 ECU for 06 ECU?
I am going to take a guess and say no, until proven otherwise.....
my thinking behind this is because of the new drive by wire, vsa, and i would assume that there would be different pin-outs for other features......
just a guess
just a guess
You may be right, but hopefully not
Like you said there may be added pins to the connectors, but hopefully these are just add ons to the existing ECU. So tis way if you did swap out it would fit, and just wouldn't make use of the extra pins.
Hopefully someone has tried this and can tells us what's up.
Unpossible man. Check this link.
http://www.s2ki.com/forums/ind...40163
i understand what you are saying, but money wise it is probably not worth it w/ the drive by wire......
EDIT: and for all the reasons listed in the link
