Vtec!
Old Aug 2, 2006 | 10:38 PM
salman's Avatar
Default Vtec!
Hi all.
I have just swaped a b16a in a civic 3G,
every thing is ok know, i have also converted it to OBD1, its working perfect, No codes Except for ELD.
the Dizzy i am using is a NON Vtec, OBD1, with just some minor mods and it was
working ok,
The problem I think am facing is, the Vtec engages louder some times and some times its not louder,
the car pull hard and some time it dosent pull that much,
The other problem is the car misfires at Idel but when i turn on the head lights it goes of,
Please Suggest, can this problem is caused by the OIL.?/
Thanks
Old Aug 2, 2006 | 10:40 PM
salman's Avatar
I have 2.5 inch piping without CAT.
No intake right now,
Old Aug 3, 2006 | 01:07 AM
salman's Avatar
Default Re: (salman)
Old Aug 3, 2006 | 06:27 AM
Jesterian's Avatar
24.243.141.75
Swap that dizzy out for one you know works, then go from there.
Old Aug 3, 2006 | 08:02 AM
E_F_9's Avatar
I though a dohc vtec motor had to have a dizzy from a dohc vtec....maybe im wrong
Old Aug 3, 2006 | 11:33 AM
E_F_9's Avatar
can anyone confirm this for me?
Old Aug 3, 2006 | 11:46 AM
si90rex's Avatar
Default Re: (MaD_VTAK)
well i'm using b16a dzzy w/ ls rotor and cap and i'm not haveing problems
they looked the same so i used it. no problem
Old Aug 4, 2006 | 01:50 AM
salman's Avatar
Default Re: (si90rex)
yeah, i dont have any problem with the Dizzy my self,
Should i try clean the vtec selenoid.
Old Aug 4, 2006 | 12:05 PM
Jesterian's Avatar
24.243.141.75
To tell the truth it really does sound like your dizzy. I suggest you try one you know to be working. I've had a problem with vtec cutting in and out like that, it was the dizzy.
Old Aug 4, 2006 | 03:22 PM
B18C1rex's Avatar
check the wiring for the cam sensor in the DISTIBUTOR. mine was lose...same problem
Old Aug 6, 2006 | 03:58 AM
salman's Avatar
I have cheked the wiring of dizzy few time all the wires are connected properly.
Some time it give me CKP sensor code 9, pushing the wires in the loom makes it go away,
Yeah ill intalla dizzy of my friends obd1 dizzzy my self,..
Old Aug 6, 2006 | 09:40 AM
Jonknee's Avatar
Default Re: Vtec! (salman)
That sounds like an eld problem.
Old Aug 7, 2006 | 02:26 AM
salman's Avatar
dont tell me that, coz i have a Eld code in my car,
code 20, cos i dont have eld in my car.
Old Aug 8, 2006 | 03:38 AM
salman's Avatar
Bump
Old Aug 8, 2006 | 03:43 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">dont tell me that, coz i have a Eld code in my car,
code 20, cos i dont have eld in my car. </TD></TR></TABLE>
What?
ELD codes get thrown after a swap. It's normal, and 99.9% of the time means nothing.
Use the proper dizzy for the wiring/engine, should solve your problem. Also, having a code thrown, that can be remove by pressing on wires, doesn't sounds like a clean swap to me. Fix it.
Old Aug 10, 2006 | 01:26 AM
salman's Avatar
ok ill do that and ill update you on this,
Old Aug 10, 2006 | 04:14 AM
EnSAn's Avatar
Don't mean to jack the thread but whats ELD stand for?
Old Aug 10, 2006 | 04:15 AM
EnSAn's Avatar
Default Re: (EnSAn)
use the search button next time. IT"S RED anyhow ELD is:
Electronic Load Detector.
I R IDIOT
Old Aug 10, 2006 | 04:51 AM
92integra_gs's Avatar
just try to use another working dizzy
Old Aug 15, 2006 | 08:28 PM
salman's Avatar
will it gona change any thing,
Old Aug 15, 2006 | 08:32 PM
crxnj's Avatar
how do you have vtec if the speedo doesnt work.?
and the dizzy has nothing to do with it..i had a b18a obd0 dizzy on my b16 for about 2 months at 1 time,,everything worked perfect..
Old Aug 15, 2006 | 08:53 PM
salman's Avatar
Default Re: Vtec! (Mr.speaker)
its Electronic VSS,
poloboy4
May 26, 2013 03:57 AM
94vtecsi
Jun 20, 2008 11:24 AM
chartg
Jun 29, 2006 06:11 PM
Stiz24
Jan 16, 2006 08:15 PM
