car wont start
Did you try putting the key in the ignition and turning it to on?
It could be alot of problems, the fuel pump and/or fuel pump fuse being one of them.
I suppose you should take a line off and see if you are getting fuel/fuel pressure. Then jump the fuel pump directly to see if it turns on, etc.
try turning the ign key over but not turning the motor over and see if you pump turns on. if not replace main fuel relay. pump may be bad but its rare. usually main fuel relay under the kickpanel driver side.sometime if you tap on it and try starting the car it will start.
