new deck installed...no sound
Old Aug 2, 2006 | 09:49 PM
sohc_coupe24's Avatar
Default new deck installed...no sound
I posted this topic in the audio/security/video forum but i didn't get any help. Hopefully you guys can pitch in some advice...
Today i started wiring up the deck to the integra. After hooking up all the wires i connected the battery and turned on teh key. The deck turned on i could hear the music pumping out of the speakers (the car hasn't been turned on for 2 years). Then i noticed that i have forgotten one of the speaker wires running out of the deck. Unable to reach it...it turned the deck upside down. However, when i turned it upside down, it went silent. The deck was still on but no sound ran through the car. I thought the wires were touching each other or were loose so i checked. That was not the case. So i quickly wired up another older deck and the speakers came alive again. Can it be that the stereo deck screwed up on me??? Thanks for the input.
Old Aug 3, 2006 | 01:59 AM
Leo C's Avatar
Night Owl
Default Re: new deck installed...no sound (sohc_coupe24)
Check the 10A fuse on the back of your head unit.
Old Aug 3, 2006 | 07:05 AM
scheistermeister's Avatar
was it a new one or old one? if it was and old one you might of had something loose in there sgort something out.
Old Aug 3, 2006 | 07:33 AM
crx_88_si's Avatar
re attach the one that stopped working. Sometime when you mess w/ the speaker wires they need to be "reset"
Old Aug 3, 2006 | 08:59 AM
The fuse is fine in back of the deck. I replaced it but that didn't help.
This was an new deck that i put in. I could have shorted something out...but i don't want to throw away a 200 dollar deck, i needed some input that might be the problem.
I reattached the speakr wires..but that didn't seem to help. IM wondering if it could be the wires coming out from behind the deck. I might have fried those.
thanks for the input
Modified by sohc_coupe24 at 1:35 PM 8/3/2006
Old Aug 3, 2006 | 11:55 AM
Leo C's Avatar
Night Owl
Default Re: (sohc_coupe24)
Get a voltmeter ( one of those pens that lights up attached to a wire) and test your pos./neg. wires leading into the H/U.
Old Aug 3, 2006 | 12:25 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (shutupnskate)
what headunit is it?
Old Aug 3, 2006 | 12:36 PM
yea..thanks i will try that tester..as for the headunit..its a cde-9852 alpine
Old Aug 3, 2006 | 12:39 PM
pmed
Old Aug 3, 2006 | 01:08 PM
if its new just return the biotch and say it didnt work
Old Aug 3, 2006 | 01:33 PM
twentyhurtz's Avatar
Default Re: (scheistermeister)
if you are getting sound, with one deck and not the other, its ovbiously an internal amp issue, (that if you are getting power to the deck and not output) anytime a speaker wire shorts to another, you lose all sound, so check that, if you have a kid, shake the cd player and get that penny he stuck in there out!! ha ha, working at audio shops- seen that one more than enough of my shares worth.
Old Aug 3, 2006 | 05:46 PM
siksdb8's Avatar
disconnect your audio leads to remove any shorts. btw the test light is not a volt meter.
Old Aug 3, 2006 | 07:43 PM
haha...all right...i guess i'll just get another h/u ...but i'll just give it a good shake before i return it...hahah
si_motor_spt
Oct 3, 2012 04:50 AM
patrickstar
Audio / Security / Video
10
Feb 18, 2011 05:15 AM
J.nguyen
Jun 27, 2007 11:08 AM
sohc_coupe24
Aug 1, 2006 06:51 PM
turbo99
14
Apr 28, 2006 08:55 AM
