keys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Go to your local Honda dealer. </TD></TR></TABLE>
the dealer may be able to look up your key code and cut you a new one
sometimes the key codes are wrong or missing
If that's the case, pop one of the lock cylinders out, and have a locksmith cut a new key from the cylinder. I recommend one of the cylinders you can live without, i.e. gas door lock, trunk lock, etc.
sometimes the key codes are wrong or missingIf that's the case, pop one of the lock cylinders out, and have a locksmith cut a new key from the cylinder. I recommend one of the cylinders you can live without, i.e. gas door lock, trunk lock, etc.
I would go to ur honda dealer
YOu'll need the VIN #, registration (bring title just in case they ask for it) that's proof that the title is in your name and the VIN # is in your name then your drivers license or passport to proove that your name is you...
Fnix
Apr 14, 2012 07:27 AM
jondancer
Jun 1, 2003 09:12 AM
