clutch install tips
What do you think??? Can you open nuts and bolts by hands? You don't need impact tools, but at least hand tools like ratchet, socket, wrench, torque wrench....
it really helps if you never done a clutch install before.. if you havent before.. i dont suggest you going on with it, if this is ur first time.. bc more then likely it wont be properly aligned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">I do not have the tool! Is it possible to install without it?</TD></TR></TABLE>
No, get the tool and test it before you start bolting things up...it might not fit exactly and you might have to wrap some electrical tape around it to get the right size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">I did it without it! Just used a ratchet handel and some electric tape to size it right. Just finished mounting up my engine, will finish everything tomorrow!
Thanks</TD></TR></TABLE>
so where is the ****** writeup *******...
...j/k man
...j/k man
I have never used the alignment tool and have done 7-8 clutch replacements so far. All of them work flawlessly. It just the matter of proper plate positioning (the center hole must be aligned with flywheel).
Powered by VTEC
Jan 26, 2008 09:03 PM
smokey2.0
21
Aug 4, 2006 02:05 AM
mickey513
Audio / Security / Video
Jul 10, 2002 11:22 AM
