Compression question??
Old Aug 2, 2006 | 08:00 PM
QuickDxEk's Avatar
Default Compression question??
Ok, Tonight I finally got my B16 into my car. Before getting the axles and everything else hooked up, I decided to do a comp test. The motor has not been run in two weeks at least. 1-120 2-50 3-90 4-90 Thinking the valves are too tight I slightly loosed the intake valves and got this 1-110 2-110 3-50 4-120 Any help would be great!! The guy before me had diffrent cams in it. He had skunk 2s. It has full ITR valvetrain and ITR cams!!
Old Aug 2, 2006 | 09:02 PM
BOOSTED RIVAL's Avatar
Default Re: Compression question?? (QuickDxEk)
Was the car at operation temp.
Old Aug 3, 2006 | 02:47 AM
QuickDxEk's Avatar
The motor has not been run in two weeks at least. I know that the compression would be accurate warm, but I just wanted to get a baseline. If the valves were too tight could this affect compression. The owner b4 me had diffrent cams.
Old Aug 4, 2006 | 06:02 AM
QuickDxEk's Avatar
UPDATE: I got my moter to run after some stupid little problems. After I let it run for about 10 min i rechecked the compression and it was 210 across the board!!
Old Aug 4, 2006 | 06:24 AM
-Gary-'s Avatar
Default Re: (QuickDxEk)
Good deal! I fugured the valves and rings had to seat themselves a little better.
I went through a simaler thing with my four-wheeler and almost bought a new engine because of it. Turns out you have to do a compression test at WOT on a 4-wheeler. It made all the difference in the world...
Old Aug 4, 2006 | 07:16 AM
doublejz's Avatar
Default Re: (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">Good deal! I fugured the valves and rings had to seat themselves a little better.
I went through a simaler thing with my four-wheeler and almost bought a new engine because of it. Turns out you have to do a compression test at WOT on a 4-wheeler. It made all the difference in the world...</TD></TR></TABLE>
your suppose to do a compression test at WOT on everything
Old Aug 4, 2006 | 08:09 AM
QuickDxEk's Avatar
Yeah, Im pretty happy!! The car has been down for two long!! Im glad the compression is fairly good, Im going need that with my ITR cams!!
importfan2
19
Oct 21, 2008 06:18 PM
lude98SH
May 17, 2008 06:17 PM
fsp31
11
Jun 7, 2005 05:18 AM
silversly
Dec 18, 2004 08:02 AM
HX_Guy
Aug 22, 2001 02:00 PM
