just got another h23 from hmotors
Old Aug 2, 2006 | 08:00 PM
xxmastermindxx's Avatar
Default just got another h23 from hmotors
just came in today, and i was wondering what you guys think i should do to it, as far as tune-up/maintenance. not bothering with any upgrades for now, other than replacing clutch.
fluids, plugs, wires, cap, maybe timing belt.... feel free to add on, thanks guys
p.s. for timing belt, should i change anything else in addition to just the belt itself?
Old Aug 2, 2006 | 08:01 PM
MadCityLude
Guest
Posts: n/a
Default Re: just got another h23 from hmotors (xxmastermindxx)
water pump, front and rear main seals
Old Aug 2, 2006 | 08:07 PM
AmauryR's Avatar
Well, if you wanna go all out then check all the seals + gaskets. Oil pan gasket, front & rear main seals (since ur doing the clutch + possibly timing belt), cam seals (both ends, incl distributor o-ring), valve cover gasket (grommets + spark plug o-rings), if you do the t-belt check the tensioner pulley & do the waterpump. that should be it for things that would be annoying to do later on (when its IN the car).
-l8r
Old Aug 2, 2006 | 08:08 PM
InvaderTrax's Avatar
Only thing I see is that the motor only has 35-40k on it, so the timing belt should be fine for another few years. Most people do it now just because it's easier while it's out. Anyway, oil, plugs, wires, cap, rotor. Also, be careful when you put it in. Lots of people tend to break off the knock sensor
Old Aug 2, 2006 | 11:06 PM
snobordboy's Avatar
Moderator
Yeah while its out save the hassle and do the t-belt, then you know when it's due as well, not a 10k guess. and as the other posts said, oil pan, front and rear mains, valve cover and cam seals, maybe even the gasket behind the oil filter housing, I think its the oil cooler gasket? that should keep your new investment happy until you want more!
Old Aug 3, 2006 | 07:16 AM
AndyD's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Only thing I see is that the motor only has 35-40k on it, so the timing belt should be fine for another few years. </TD></TR></TABLE>
Mileage is not the only thing to consider when determining if the timing belt needs to be changed. Age is a concern too.
Change the timing belt now.
Old Aug 3, 2006 | 07:39 AM
MadCityLude
Guest
Posts: n/a
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
Change the timing belt now.</TD></TR></TABLE>
Absolutely correct. These engines are 10 yrs old no matter how you look at it. The have been banged moved and transported halfway around the world. Do as much now as you can and you will have fewer problems later.
Old Aug 3, 2006 | 07:46 AM
prelittlelude's Avatar
i would put the balancershaft seal retainer in that keeps that seal from backing out.. happend to me on my H , lucky i had a oil press gauge.
Old Aug 3, 2006 | 04:51 PM
Default Re: just got another h23 from hmotors (Ether Way)
thanks for all the responses so far guys
so far, everything listed has been:
timing belt
water pump
front and rear seals
oil pan gasket
cam seals
valve cover gasket
only one i have done is the oil pan gasket, and im definitely doing the t-belt. as far as the others, is it more preventive or is it a must be done kinda thing? i just want to get the absolute essentials right now because after the motor + shipping, i dont have much money left right now, and i gotta get this motor in time for monday
Old Aug 3, 2006 | 05:52 PM
SKDRCR's Avatar
Timing belt is easy in or out of the car, the rear main seal though,
there's no getting around that.
Old Aug 3, 2006 | 05:56 PM
twistedbydezign's Avatar
i would say definitely do the water pump, front and rear main seals, balance shaft seal, and the recall or advisory or whatever balance shaft retainer
Old Aug 3, 2006 | 06:02 PM
Default Re: just got another h23 from hmotors (twistedbydezign)
i cant find the freakin bal. shaft retainer at any store in my area, and this HAS to be done for monday. everything else i can get today or in a day.
also, a $30 goodyear timing belt? opinions?
Old Aug 3, 2006 | 06:24 PM
i hear gatorbacks are good for autozone quality stuff, but for timing belt, you want to stick with a honda belt, goto http://www.honda.com and sign up for the owners link, you can order parts online, pick it up at your local dealership, and you pay a lot less, like http://www.hondaautomotiveparts.com prices, and most dealership parts departments should have the retainer, it was basically a recall for almost every 90-97 accord (f series motors), 92-96 preludes (i think 97-01 as well), acura cl's with f22 motor, tl or legend if they had f series motor in the 90s, etc....speaking of which try an acura parts department as well....
Old Aug 3, 2006 | 06:43 PM
How much does the belt cost by ordering online like that? It was only $50 when I walked in and bought one
Old Aug 4, 2006 | 08:08 AM
shutta's Avatar
i paid $80 for my greddy T-belt
Old Aug 4, 2006 | 08:20 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">
also, a $30 goodyear timing belt? opinions? </TD></TR></TABLE>
No, order from http://www.hondaautomotiveparts.com or http://www.slhondaparts.com. Use Honda parts for important stuff like that...
Old Aug 4, 2006 | 09:35 AM
marks_lude's Avatar
Default Re: just got another h23 from hmotors (Hawkze_2.3)
Go with the sure thing and get OEM timing belts. (so u know there are two belts... timing and another for the balancer)
also do the clutch now. its words easier when the **** is out of the car.
hometheaterman
Jun 4, 2010 11:17 AM
doostin
Feb 1, 2009 04:45 PM
EKSedAndy
Apr 9, 2007 08:42 AM
gator88
Mar 5, 2007 05:22 PM
TeaAddict
Nov 27, 2006 10:12 AM
